You are trying to set a different logo for each language on your multilingual website using WPML. Despite using WPML's 'String Translation' feature and translating the logo IDs for each language, the logo does not change when switching languages.
We recommend following these steps to ensure the logo changes correctly for each language:
1. Navigate to WPML >> String Translation page.
2. Click on the “Not seeing strings that you are looking for?” section and then click the Admin texts translation link.
3. Search for the logo ID and enable its translation.
4. Return to the WPML >> String Translation page and add the translated logo ID.
This should allow the correct logo to display for each language on the frontend. You can update the translation as needed from the String Translation page.
If this solution does not resolve your issue, or if it seems outdated or irrelevant to your specific case, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If further assistance is needed, please open a new support ticket.
Last updated by 6 months, 3 weeks ago.
Assisted by: Noman.
