Last updated by jiriJ-8 1 year, 7 months ago.
April 23, 2024 at 4:36 pm #15557584
jiriJ-8
I´m strugling with translation menu and submenu. The translation showed me the same string as in the default language. I tried to make new menu for every language manually but than it rewrite to all languages.
https://wpml.org/forums/topic/issue-with-translation-menu-and-submenu/
April 23, 2024 at 4:50 pm #15557613
WPML Supporter since 08/2022
Thanks for your patience.
Here is the ticket and I will need to closely examine your website. Therefore, I will require temporary access (WP-Admin and FTP) to a test site where the problem has been replicated, if possible. This will enable me to provide better assistance and determine if any configurations need to be modified.
April 25, 2024 at 8:50 am #15564207
jiriJ-8
Hi, from which country do you connect from?
April 25, 2024 at 9:36 am #15564398
jiriJ-8
Try it now. Thanks
April 26, 2024 at 5:52 pm #15571652
Thank you for your patience.
I apologize for the delayed response. I wanted to inform you that I'll need a bit more time to investigate this further. I'll get back to you as soon as possible!
April 29, 2024 at 6:14 pm #15578510
I regret the inconvenience caused by the delays. Upon review, I can synchronize the menus for you, with the exception of those featuring custom menu icons. Unfortunately, it appears that these custom menus with icons do not support the menu sync feature offered by WPML. Here are the steps you can take to manually translate the menus for your other languages shown in the screen recording here hidden link
Could you give this a try and let me know how it goes?
April 30, 2024 at 6:25 am #15579326
jiriJ-8
Hello Kor,
thank you. I added the last language and translated all. There are also credits if you need to translate and synchronize the menu. Can you please do it for me? I will add the icons later. Thank you
Regards
Lena
May 1, 2024 at 3:46 pm #15584425
jiriJ-8
why one part of the menu isn´t translated if I change it to other languages?
May 1, 2024 at 6:56 pm #15584804
Thanks for your reply.
Could you tell me how it should be called in German and Magyar? Please list it here and I will complete the translation for you.
May 2, 2024 at 5:16 am #15585416
jiriJ-8
Hi Kor,
if needs to be translated here (see attached print screen), I will do it.
May 2, 2024 at 8:01 am #15585997
Yes, that's the correct step to translate custom links. Please proceed.
May 2, 2024 at 10:52 am #15586741
jiriJ-8
Thank you, you can close the ticket
The topic ‘[Closed] Issues with translating menu and submenu’ is closed to new replies.
