You are experiencing issues importing products using WP All Import with the WPML Import Export plugin installed. Despite following all instructions, you end up with more products in English than in another language, even though your Excel file has equal products listed as translations.
We found that the import setting 'Skip WooCommerce products if their data in your file has not changed' was enabled, which we disabled and ran another successfull import.
If this solution does not resolve your issue or seems outdated, please check related known issues at https://wpml.org/known-issues/, verify the version of the permanent fix, and confirm that you have installed the latest versions of themes and plugins. We highly recommend opening a new support ticket at WPML support forum for further assistance.
This topic contains 18 replies, has 1 voice.
Last updated by Andreas W. 3 weeks ago.
April 21, 2026 at 9:57 am #17983500
Honestly, it is usually not the responsibility of our support team to run such imports.
I suggest you give this a test and adjust the templates to your needs. If you can replicate the issue, let me know, and I will be glad to take a look at it.
Important:
Make sure to keep this unique identifier in the last step:
{title[1]} - {product_id[1]} - {sku[1]}{size[1]}
April 22, 2026 at 10:01 am #17986976
Sevag
Yea Of course i'm not asking you to do i for me 🙂
April 22, 2026 at 11:20 am #17987215
Sevag
I imported with your settings with the unique identifier {title[1]} - {product_id[1]} - {sku[1]}{size[1]} and still the same wrong results. Also imported the categories separately.
I've following you docs and everything please help me to fix this issue, it's taking too long already.
April 24, 2026 at 6:18 am #17991663
You used the import setting:
- Skip WooCommerce products if their data in your file has not changed
I disabled this setting and ran another import.
See screenshot.
