Last updated by Andreas W. 1 year, 1 month ago.
January 3, 2025 at 4:09 pm #16561977
mauritsH
I am currently encountering an issue with the WPML plugin in combination with WPC Linked Variation for WooCommerce. We use this plugin to link different color variations of products so that each variation has its own page. This has always worked perfectly, but now it is unexpectedly causing problems with translations of certain products. The issue seems to occur with the translation of an attribute. The plugin works via a shortcode. In the default language, everything functions as expected, but in the translated version, the same shortcode causes problems, mixing up the HTML code. Link to a page where the issue can be seen: hidden link I expected to see: How it looks like on the dutch page: hidden link
In the translated version, the shortcode causes problems, mixing up the HTML code.
Could you help us investigate what WPML is doing with this shortcode on a translated page?
January 3, 2025 at 7:12 pm #16562473
Surely I will be glad to assist you on this matter but I have a few questions first.
How exaclty does this shortcode look?
Are the original products created in Dutch?
Also, could it be that the site used NL as site default language and the default language was changed to EN?
Are you using global attributes that were created at Products > Attributes or did you declare the attributes directly on your original products?
January 3, 2025 at 7:31 pm #16562503
I have installed a sandbox with WPML,Elementor PRO, WooCommerce and WPC Linked Variations for WooCommerce.
Could you please try to recreate the issue here?
One-Click-Login:
Please leave me a comment on this ticket once you are done with this task.
The topic ‘[Closed] Issues with WPML and WPC Linked Variation’ is closed to new replies.
