The client was experiencing multiple issues on their WPML-translated website, including Smart Slider and Presto Player not loading, inconsistent language switching in the menu bar, and untranslated menu items. Specific problems in Hebrew and Arabic included pages not loading and icons overlapping text.
We resolved the issue with Smart Slider and Presto Player not loading by disabling the Object cache plugin and Email encoder, due to known compatibility issues. You can find more details on this problem here: https://wpml.org/de/errata/email-encoder-protect-email-addresses-and-phone-numbers-there-is-a-problem-connecting-to-automatic-translation/.
For the other issues, we have opened separate support tickets to address each one individually, ensuring clarity and focused assistance. You can follow these issues on their respective threads here:
If the solution provided here does not resolve your issue or seems outdated, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If issues persist, please open a new support ticket with us for further assistance.
Last updated by Dražen 1 year ago.
Assisted by: Dražen.
May 1, 2025 at 7:46 am
anandB-2
I am experiencing multiple issues on my WPML-translated website, hidden link. I am trying to resolve problems related to Smart Slider, Presto Player, language switching, and menu translations.
Smart Slider and Presto Player are not loading in any language, only the shortcode is displayed. Language switching is inconsistent for the menu bar, leading to 404 errors. Several menu items remain untranslated.
How can I resolve the issue with Smart Slider and Presto Player not loading?
What steps should I take to fix the inconsistent language switching in the menu bar?
How do I ensure all menu items are translated correctly?
May 1, 2025 at 8:43 am #16985946
anandB-2
my issue of the pages not loading is not mentioned in this ticket
smart slider and presto player is fixed but in some languages the header and footer section is loading but the body section is not loading
if you look at the images there ate 4 sections under fibc but 3 of them are loading perfectly fine in Korean language
but
the last one only header and footer is loading, same is for other languages but different page though
May 1, 2025 at 8:49 am #16985966
Dražen
I checked, please disable your object cache for your website and try to re-translate the page.
If you still have issue, please provide staging site so I can further check the issue and disable plugin.
Drazen
May 1, 2025 at 8:57 am #16985997
anandB-2
we have not enabled object cache for this website ?
you can use this as the staging site no issues since we have backup dont think it could be any problem
May 1, 2025 at 9:15 am #16986111
Dražen
I have disabled the Object cache plugin and Email encoder, since there is a known issue and the plugin is not compatible:
- https://wpml.org/de/errata/email-encoder-protect-email-addresses-and-phone-numbers-there-is-a-problem-connecting-to-automatic-translation/
Your translated page works fine now:
- hidden link
Drazen
May 1, 2025 at 9:26 am #16986199
anandB-2
yes i noticed most of the issues are fine now
but in Hebrew language there is 2 issues
2 pages are not loading
and on the header in Arabic and Hebrew the icon is overlapping the text on the top phone icon
May 1, 2025 at 9:31 am #16986219
anandB-2
this page body is not loading
this page images are not loading
same way we have in other pages other languages
easy solution to this ?
or we have to manually go through each and every language and each and every page to see where the body of the website is not loading
May 1, 2025 at 9:34 am #16986231
Dražen
thanks for getting back.
We limit 1 issue per ticket to keep things clear. This will help other users with similar problems to find solutions when searching the forum.
I have opened a new ticket for you, and lets continue there:
- https://wpml.org/forums/topic/split-this-page-body-is-not-loading/
- https://wpml.org/forums/topic/split-page-images-are-not-loading/
Drazen
