This topic contains 0 replies, has 1 voice.
Last updated by nikiforosB 9 months, 1 week ago.
March 12, 2025 at 3:08 pm #16807939
nikiforosB
I am trying to translate Jet Engine glossary fields on my site hidden link using WPML. I followed the steps to translate the glossary fields: created glossary fields, edited the English post, set the metabox to Copy in WPML settings, translated strings, and saved the post.
When I load the Greek version of the post, instead of showing the translated label Κόκκινο, it shows the original value 'red'.
Why is the translated label not showing in the Greek version of the post?
Is there a step I missed in the translation process for Jet Engine glossary fields?
March 12, 2025 at 3:45 pm #16808195
nikiforosB
The problem happened because I had set both value and label in lowercase so I had translated the value too in Greek which I shouldn't. It works fine now. You may delete this ticket if needed.
