You are using the JetSmartFilters plugin to generate filters for JetEngine custom fields, but the filter labels are not being translated into secondary languages.
If you're experiencing this issue, we recommend checking if the filter was created in the correct language. If not, you should delete it and recreate it in the correct language. Alternatively, you can edit the existing filter, add the correct filter labels in the correct language, and then update the filter in both languages.
This solution might be irrelevant if it's outdated or not applicable to your case. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the issue persists, please open a new support ticket at WPML support forum for further assistance.
Last updated by Raul Pina 1 year, 3 months ago.
Assisted by: Osama Mersal.
January 10, 2025 at 10:23 pm #16583364
Raul Pina
I am using the JetSmartFilters plugin to generate filters for JetEngine custom fields on my site hidden link. I want the filter labels to be translated into secondary languages.
The filter labels generated by JetSmartFilters for JetEngine custom fields are not translated in secondary languages.
Is the documentation on https://wpml.org/errata/jetsmartfilters-smart-filters-custom-fields-are-not-translated-in-secondary-languages/ still valid?
How can I fix the issue of filter labels not being translated?
January 12, 2025 at 1:17 pm #16585653
Osama Mersal
The workaround you shared is for an issue that is fixed. Please log in to this hidden link and try to replicate the issue.
If the issue is replicable, please let me know how to reproduce it so I can check it and consult our compatibility team if needed.
Osama
January 12, 2025 at 7:19 pm #16586353
Raul Pina
Hello.
Thanks for the reply, I see that on my website the filter languages ​​are confused (see image). How can I change that?
On the sandbox site it looks ok .
New threads created by Dražen and linked to this one are listed below:
https://wpml.org/forums/topic/split-website-is-slow/
January 13, 2025 at 8:03 am #16586835
Osama Mersal
If the filter is created in the wrong language, you would need to delete it and re-create it.
Alternatively, you can edit the filter, add the correct filter labels in the correct language, and update the filter in both languages.
Osama
January 13, 2025 at 8:53 am #16586944
Raul Pina
I recreate the filters and now its ok.
Thanks for the help!
