The client is using LightspeedHQ to manage stocks between their physical store and WooCommerce webshop, which has been translated into English and German using WPML. They noticed that orders placed on the translated versions of the site are not being synced to the LightspeedHQ system. This issue arises because WPML creates duplicates of products for each translation, each with different product IDs, which LightspeedHQ does not support.
We suggested verifying the REST API responses from the client's website to ensure they are correct and can be retrieved properly in both languages. We recommended exploring the use of a dedicated plugin that supports WPML and can handle translated products. Two potential plugins to consider are:
If these plugins do not resolve the issue, we advised checking with the plugin authors to confirm whether their solutions support the needed functionality and how they process the data. Additionally, we confirmed that WPML's behavior of creating new product IDs for translations is standard and cannot be adjusted.
If this solution does not apply or is outdated, we recommend opening a new support ticket. We also highly suggest checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. For further assistance, please visit our support forum at WPML Support Forum.
Last updated by Dražen 3 months, 2 weeks ago.
Assisted by: Dražen.
December 5, 2025 at 12:58 pm #17638547
Dražen
I’m sorry to hear that. Unfortunately, it seems there isn’t much that can be done in this situation, as the workflow isn’t supported. This is how WPML — and most multilingual plugins — typically operate.
As a final option, you might want to check with the third-party plugin author to see whether their solution could work for your use case.
From the WPML side, if there’s anything else we can do to help or provide guidance, please let us know — we’ll be happy to assist.
Drazen
