This topic contains 16 replies, has 0 voices.
Last updated by Bobby 3 months, 1 week ago.
Assisted by: Bobby.
October 28, 2025 at 3:49 pm #17526768
nathanK-6
I am trying to use WPML to keep my WooCommerce products, especially bundles, correctly translated and synchronized between languages. I expected stable and automatic synchronization where bundle products and their variations remain properly linked and appear in both translations without needing to re-run WPML synchronization each time.
WPML constantly breaks the links between translated products and variations, even without updates or changes. It slows down my entire website and requires manual synchronization after every update or order. Products randomly disappear from translations, bundle items are missing from orders, and variations stop working. I need to re-sync WPML almost every time I receive an order or make a small change.
Why does WPML break the links between translated products and variations?
How can I achieve stable and automatic synchronization between languages for bundle products?
October 29, 2025 at 11:15 pm #17530921
Bobby
WPML Supporter since 04/2015
Are you able to reproduce this behavior on command? Meaning are there steps that we can follow that would reproduce this issue or does it happen randomly?
What steps do you take to re sync them?
October 30, 2025 at 1:09 pm #17532800
nathanK-6
It happens randomly, but I can reproduce it right now because the issue is currently persisting. At the moment, even if I delete the product and redo the translation, it’s impossible for me to get all the bundled products included in the translation. I always end up missing 2–3 products..
I Could give you admin access to my website if needed.
November 3, 2025 at 8:11 pm #17543373
nathanK-6
Any update please ?
November 3, 2025 at 11:48 pm #17543583
Bobby
If possible please provide me with the steps I need to take to reproduce the issue, as well as a specific product we can test so we are testing the same product to avoid mix ups.
Thank you,
Bobby
November 6, 2025 at 7:44 am #17552314
Bobby
If possible please verify them as I am not able to access the backend.
The previous private reply can be edited if need be.
November 9, 2025 at 12:01 am #17559712
nathanK-6
Please try again, I have tried both and they seem to work fine now.
Thanks !
November 11, 2025 at 12:09 am #17564489
Bobby
When I duplicate the product the issue is reproduced, however, when I create a new product and add bundled items it looks like it's working as expected.
Can you please try this and confirm if the issue is happening with new products.
November 14, 2025 at 4:44 pm #17579957
nathanK-6
Please accept my apologies for the delayed response, I did try many time and by creating a new product it does not seem to have any issues BUT, because otherwise all the fun goes away.
It's already the 4th time it happened to me, where I delete and create again the product for it to work, wich mean, by doing an update or maybe changing stock, in one or 2 weeks, the product will once again have an issue.
Moreover, when translating, if we have applied a variation filter to the product, the translated version does not include it, we have manually go in the language version of the product and edit it.
November 14, 2025 at 11:54 pm #17580359
Bobby
Thank you for updating me!
I would like to further test this using the latest version of the plugin, if possible please update to version 8.5.3 and let me know your results.
(I have attempted this but it's asking for the subscription details.)
November 18, 2025 at 9:39 pm #17589785
nathanK-6
Hi, Sorry for the late reply, if you are talking about the bundle product plugin I cannot update it, as I can only have on active premium license at a time. But I was talking about WPML update or Woocommerce update that can cause the issue, never updating the bundle plugin.
November 18, 2025 at 11:05 pm #17589857
Bobby
I understand, are you able to update it to the latest version in the main site, and then upload it manually to staging?
Our plugins compatibility is based on the latest versions, I cannot confirm if the older version is compatible with the latest versions of WPML.
November 21, 2025 at 10:36 am #17598364
nathanK-6
Hi !
Woo Product Bundle plugin updated on the staging website, sorry for the delay;
November 24, 2025 at 4:16 pm #17605686
Ilyes
Timezone: Pacific/Easter (GMT-05:00)
My colleague Bobby is currently on vacation, so I will be taking care of your request in the meantime.
I have recorded this video just to explain where I'm at and what the next steps are : hidden link
Let me know if I'm missing anything,
December 7, 2025 at 5:38 pm #17642260
nathanK-6
Hi, Sorry I thought I had answer but did not.
I'am not understanding the point of your video ... nor how this should help me understand what your are doing ...
Its been more than a month, no issue or bug have been found when it's quite simple to understand.
Your plugin after each update does not sync up the bundled product and mess up the whole point of using it as I have to create new product each time and I can't due to order traceability;
So please juts find what could be the issue, you have access to to the whole staging website with the plugin, it is quite expensive to each time translate again the whole new product + the price of the plugin itself for all this work and bug, when its mention the plugin is compatible, an option to check that the bundle product are synchronised correctly and check it will be the only way to go, your video does not help at all understanding what your actually doing ....
The topic ‘[Closed] Major compatibility woocommerce product bundle and performance issues’ is closed to new replies.
