Last updated by silkeK-4 1 year, 8 months ago.
Assisted by: Lauren.
| Author | Posts |
| August 7, 2024 at 3:40 pm #16048975 | |
silkeK-4 |
Background of the issue: See this issue here: 2. I am using the default language switcher in the footer and it works fine on all pages. But on the stand-alone-maps, it does not link to the translated map but to the homepage. See this issue here: hidden link Symptoms: Questions: |
| August 7, 2024 at 3:53 pm #16049102 | |
Lauren |
Please let me know if you are able to reproduce the issue with Maps Marker Pro on the test site that I set up. |
| August 7, 2024 at 6:40 pm #16049709 | |
silkeK-4 |
hi lauren, i meanwhile found out that i cannot install the plugin on the test site, as the licence is limited to the domain we are using it with. so how can we go on from here? do you have the maps marker pro plugin available at your end to install it on the test site? in case you will have a look at our website, the links i provided above: we added language switchers in the marker popup, those are manually coded and work. yet, those at the footer below the stand-alone-map, that are automatically generated by wpml, still don't work |
| August 12, 2024 at 1:16 pm #16062397 | |
Lauren |
I do not have a copy of Maps Marker Pro. Do you have any contact information for the plugin author? I'll be happy to reach out and ask for a copy so we can test on a clean install. |
| August 12, 2024 at 3:58 pm #16063082 | |
silkeK-4 |
this is the homepage for the plugin hidden link and this is their email-address: support@mapsmarker.com we also opened a ticket there: [#PPU-982DA-A8A] Inkompatibilität MMP & WPML String Translation - if you want to refer to that. |
| August 16, 2024 at 1:54 pm #16078533 | |
Lauren |
I've sent an email requesting a temporary license but have not heard back yet. Have you heard anything back on their end from the ticket you opened there? |
| August 20, 2024 at 11:50 am #16086898 | |
silkeK-4 |
thank you for your message, sorry, i have been on the road for some days with no possibility to answer here. meanwhile, we were able to solve the problem with the search not working. we asked mapsmarker to give you this license, still waiting for their answer. do you have any idea about possible reasons for the problem? |
| August 20, 2024 at 4:40 pm #16087887 | |
Lauren |
I have not heard back from the author yet in regards to a license. If you would like me to login to your site and take a look at these stand alone maps, I'll be happy to. I have marked the next reply as private so that you can safely share credentials if you like. |
| August 23, 2024 at 8:22 am #16097592 | |
silkeK-4 |
hi lauren, according to the authors of mapmarkerpro, this second issue has nothing to do with wpml either but is on their side. that's what they now finally told us. so thank you very much, kind regards, silke |
