This topic contains 13 replies, has 0 voices.
Last updated by gloccos 11 months, 1 week ago.
Assisted by: Ahmed Mamdouh.
| Author | Posts |
| May 27, 2025 at 1:15 pm #17077682 | |
gloccos |
| May 27, 2025 at 1:48 pm #17079026 | |
Lucas Vidal de Andrade WPML Supporter since 11/2023
Languages: English (English ) Spanish (Español ) German (Deutsch ) Portuguese (Brazil) (Português ) Timezone: Europe/Vienna (GMT+02:00) |
Hello there, You can share access here. I'll log in to your website to test how sent Translations behave, and to check for errors. The required fields can be found below the comments section. The information you enter is private, i.e. only you and I can see it and have access to it. IMPORTANT Please make a backup copy of the site files and database before giving us access. - If you do not see the wp-admin/FTP fields, this means your post and site login details are being made PUBLIC. DO NOT post your website details if you do not see the required wp-admin/FTP fields. If you do not, ask me to enable the private box. The private box looks like this: hidden link |
| May 27, 2025 at 6:50 pm #17080509 | |
Thank you for sharing the details. I've forwarded your request to our external translation services team and will get back to you once I have or need more information. Thank you for your patience. |
| May 28, 2025 at 1:15 pm #17083623 | |
gloccos |
Hi, any news please? |
| May 28, 2025 at 6:57 pm #17085245 | |
Hello there, Thank you for waiting. Our team checked and there was an error, which seems to be already solved. Can you please confirm if you can see the latest job in the Matecat system? If so, everything should be up and running 🙂 Let me know. |
| May 29, 2025 at 7:03 am #17086208 | |
gloccos |
Hi, Unfortunately, we can’t see any of the old jobs. I also tried submitting a new one, but we can’t see that either. |
| May 29, 2025 at 7:32 am #17086418 | |
gloccos |
Seems the exact same issue here: |
| May 29, 2025 at 8:35 am #17087013 | |
Ahmed Mamdouh Supporter Languages: English (English ) Arabic (العربية ) Timezone: Africa/Cairo (GMT+03:00) |
Hello, This is Ahmed Mamdouh from the translation proxy team, and I'll help you with this ticket. I checked the issue and found an error that most likely caused the problem. I then attempted to replicate the issue, but everything went smoothly. Please check if you can see the latest job I sent. Best regards, |
| May 29, 2025 at 10:32 am #17087538 | |
gloccos |
Hello Ahmed, Unfortunately, we can see nothing. Milos |
| May 29, 2025 at 11:25 am #17087740 | |
gloccos |
Would it help if you had access to our Matecat account? How could I securely share the login credentials with you? |
| May 29, 2025 at 2:59 pm #17088876 | |
Hello, No need to provide me with the Matecat credentials, I already opened an investigation with the Matecat support team, and I sent them all the needed details, and I'll keep you posted on the updates. Thanks for your patience and cooperation. |
| May 29, 2025 at 4:48 pm #17089224 | |
johannesB-39 |
Hello Milos, Johannes here from the other thread: https://wpml.org/de/forums/topic/problem-with-matecat-integration-jobs-arent-send-from-wpml-to-matecat/#post-17086298 Luckily, Matecat could solve this issue for me! Did you get in contact with Matecat Support too? Hope they can help you, they are pretty responsive. Cheers, Johannes |
| May 30, 2025 at 7:01 am #17090530 | |
gloccos |
Hello Ahmed, thanks — feel free to add me to the conversation with Matecat support if it helps: milos.debnar@glocco.com |
| May 30, 2025 at 7:50 am #17090696 | |
gloccos |
Hi Ahmed, Milos |
