You are experiencing issues where some product options are not showing translated text in German on your e-commerce site, even though they appear correctly translated in the translation editor.
First, try editing the original product and then open the translation editor to complete the translation to 100%. If this does not resolve the issue, confirm whether the problem persists by creating a new test product and translating it to confirm if this is a general bug or the if the issue was only related to a specific product.
If these steps do not resolve your issue, it might be due to an outdated solution or a different underlying problem. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the problem persists, please open a new support ticket at WPML support forum for further assistance.
Last updated by Andreas W. 1 year, 4 months ago.
November 3, 2024 at 7:51 am #16357479
haroldd-4
I am trying to sell computer systems using composed products on my site hidden link. The main text is translated correctly using WPML.
At random, the option part of the product is not translated when switching to German. When I press 'edit translations', it looks like the translation is fine, but it is not showing. For example, on the page hidden link, the text at 'barebone' is not translated.
Why are some product options not showing translated text in German?
How can I ensure all parts of the composed products are translated correctly?
November 4, 2024 at 8:54 pm #16363405
This does only happen on some products?
Did you already try to edit the original product, then open the translation editor and complete the translation again to 100%?
If this does not solve the issue, could you please confirm if the issue is replicable when creating a new test product and translating it?
November 4, 2024 at 10:03 pm #16363499
haroldd-4
Some products are translated correctly, other are missing translations parts
when i pressed edit translation, it goes back to the dashboard..
As i mentioned some products are translated correctly, even when i take the proudct i send you , and press edit translation, its translated correct, but it doesn't show.
2 morrow i'l make a test product and update you
November 5, 2024 at 6:44 pm #16368835
On the affected products, pLease try to edit the original product, save it and then complete the translation.
If this will not solve the issue I would be glad to have a look into this for you.
November 6, 2024 at 8:39 am #16370161
haroldd-4
Thankx, it looks that it did the trick.
I'l go through all the other products
Thankx 4 your help
