If you're experiencing issues with WPML's multi-currency settings and the Yoast plugin displaying abnormally on your product page, it might be due to a compatibility issue.
We recommend following these steps to resolve the issue:
1) Visit the WPML>>Languages>>Language switcher options in your site's admin area.
2) Add the following CSS code to the *Additional CSS* field:
.wcml_custom_prices_block {
    clear: both;
    padding-top: 10px;
This CSS adjustment should help align the elements correctly. Additionally, we have documented this issue in our errata. For more details, please visit https://wpml.org/errata/yoast-seo-woocommerce-styling-conflict-with-set-prices-in-other-currencies-feature-for-variations/.
If this solution does not resolve your issue or seems irrelevant due to being outdated or not applicable to your case, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the problem persists, please open a new support ticket for further assistance.
This topic contains 10 replies, has 3 voices.
Last updated by Bigul 1 year, 6 months ago.
Assisted by: Bigul.
August 28, 2024 at 8:53 am #16113463
greloZ
I am trying to edit the product page on my site hidden link. I am using WPML for multi-currency settings and the Yoast plugin.
The multi-currency currency settings and the Yoast plugin are incompatible and display abnormally when editing the product page in the background.
How can I resolve the compatibility issue between WPML's multi-currency settings and the Yoast plugin?
August 30, 2024 at 9:33 am #16123929
Dražen
Thanks for contacting us.
I have just checked with only Yoast SEO and the issue doesn't happen.
1) Can you please confirm issue happens when using only WPML plugins, Wocommerce, and Yoast plugins + addons?
2) Please try to recreate the same issue and install plugins that are needed to see a problem, I suspect it could be Yoast for Wocommerce, but I do not have versions to confirm this.
- hidden link
Drazen
August 31, 2024 at 3:50 am #16126930
greloZ
After I disabled Yoast for Woocommerce, everything returned to normal. It should be the conflict caused by Yoast for Woocommerce
September 2, 2024 at 11:05 am #16131164
Bigul
Thank you for the updates. This may be a compatibility issue with the *Yoast SEO: WooCommerce* plugin. Therefore we have created a test site in our Sandbox Server for further debugging of this bug. Reproducing the issues in a fresh/minimal installation will help us a lot in debugging and also we can troubleshoot the issue without affecting your live site.
Please try the following steps and make sure the bug exists or is not on the sandbox site.
1) Click this URL to visit the Sandbox site backend - hidden link
2) Configure the WooCommerce like your live site
3) Configure WPML like your live site and activate WPML add-ons
4) Install and activate *Yoast* & *Yoast SEO: WooCommerce* plugin
5) Create a test product and translate it
Bigul
September 5, 2024 at 2:02 am #16142915
greloZ
The problem has been reproduced in the sandbox and can be seen in the product variant options
September 5, 2024 at 4:47 pm #16146028
Bigul
Thank you for trying to reproduce the issue on the sandbox site. But one doubt. I have set a secondary currency (Euro) in the sandbox site - hidden link
Then it shows the expected results in the Product Edit screen. Please check the attached images for more details and let us know your feedback.
Bigul
September 6, 2024 at 1:48 am #16147058
greloZ
Only the WPML currency selection button is displayed in a strange position
Other aspects seem to be fine
September 6, 2024 at 8:56 am #16147797
Bigul
Thank you for the updates. Please check the attached images. Normally it will be aligned correctly. It looks like a conflict with the *Yoast SEO options* block.
So you want to list the WCMLcustom prices block just above the Yoast SEO options block, am I correct?
Bigul
September 9, 2024 at 1:32 am #16153326
greloZ
Yes, it looks much better, how do I do it?
September 9, 2024 at 3:36 pm #16157534
Bigul
Thank you for the feedback. I have escalated the ticket to our compatibility team for further checking. We will get back to you as soon as possible. Please wait.
Bigul
September 11, 2024 at 7:56 am #16164799
Bigul
We are getting the expected results in the Sandbox site after the following steps.
1) Visit WPML>>Languages>>Language switcher options
2) Add the following CSS code *Additional CSS* field
    clear: both;
    padding-top: 10px;
We also released an errata for this conflict. Refer to this post for more details - https://wpml.org/errata/yoast-seo-woocommerce-styling-conflict-with-set-prices-in-other-currencies-feature-for-variations/
Please try the workaround on your site after a backup and let us know your feedback.
Bigul
September 12, 2024 at 1:54 am #16168553
greloZ
Thank you very much, the problem is solved
