This topic contains 34 replies, has 0 voices.
Last updated by Kor 9 months, 2 weeks ago.
October 16, 2024 at 11:18 am #16295036
WPML Supporter since 08/2022
Thanks for your reply. The issue still persists even after deactivating all plugins and switching to the default theme.
I will need to escalate this. I kindly ask for a snapshot of the site. Alternatively, with your permission, I can create one myself. For this purpose, I typically recommend using the free plugin "Duplicator." If you're already familiar with Duplicator (https://wordpress.org/plugins/duplicator/), please skip the following steps and simply send me the archive file you downloaded.
October 16, 2024 at 2:00 pm #16296109
I've escalated this and I will come back to you once I've feedback.
October 17, 2024 at 11:40 am #16299921
Could you please recheck now and let me know if everything is working fine for you? I've tested it on the homepage and I'm able to translate to Italian and to any other languages without issues.
October 18, 2024 at 6:59 am #16302838
Vladimir
Can you please explain me what was the issue and what you did to fix the problem, so I can do it on production.
October 18, 2024 at 10:48 am #16303907
Our 2nd Tier support fixed the issue on your server database. This is what they mentioned.
The translators have the language pair "fr-be" but that kind of language code is not present on the site.
Trying to translate a page, tries to load the translation pairs for the user. As such language is not found, the "code" is return as false and this produces the error that we have here. A simple fix is to remove or edit the language pairs for the user - user meta key wp_language_pairs
Another possibility is adding a custom language with code "fr-be" in our case.
The attached screenshot is the value and we've changed it to the below to fix it.
a:1:{s:2:"en";a:1:{s:2:"fr";i:1;}}
October 21, 2024 at 7:56 am #16310603
Vladimir
Now when I add new text block on the homepage of english(default language), and when I go to translation editor on other languages I have the option to translate the page, when I try to translate on german it just puts english content in the german section, so anytime I save german translation I lose all of the translation, and the new element is not being translated on any languages. sending screenshots.
wpml-newsection.png displays the section in english page, wpmlpulling english... displays the advanced translation editor pulling the english language in german place when trying to edit the existing german translation, wpml-newsection2.png displays the german homepage where is visible that despite being translated in advanced translation editor it's showing the original english wording, and that's the same for every language
October 21, 2024 at 4:51 pm #16313786
Thank you for your response.
From the screenshots you shared, are you indicating that you initially translated the page into German without any problems?
However, whenever you edit the translations, the primary English content is being copied over to the German version, thus replacing the previously translated text?
October 22, 2024 at 6:21 am #16315149
Vladimir
Yes, that is exactly the problem.
October 22, 2024 at 10:35 am #16316511
I'm working on the homepage here hidden link and this is what I've done in an attempt to replicate the issue.
1. I've made minor edits to the German language translations as a test as shown in the attached screenshot.
2. Then, I made some edits to the primary language English.
3. I retranslated the German language page and all my previous edits are still there.
I cannot replicate the issue you had there. Maybe you can give it another try? Even better if you can record a short screen recording of the issue.
October 23, 2024 at 6:55 am #16320063
Vladimir
Hey, I have screen recording, you can see the issue on french homepage. Here is the link to the screen capture:
October 23, 2024 at 5:41 pm #16323030
I previously tested the German language, and the translated content did not revert back to English.
I've also reviewed the French translation, and some portions have changed back to English. Could you please retranslate it to French for testing purposes?
After that, I’ll attempt to make edits to the primary English language page to see if that’s affecting the translated French version.
October 25, 2024 at 11:35 am #16330396
Vladimir
It's back to french content. Can you please speed this up, because this is a really big inconvenience for the client
October 28, 2024 at 8:46 am #16336376
Vladimir
Is there any news regarding this?
October 28, 2024 at 11:25 am #16337450
Thanks for your reply. I apologize for the delay due to the weekend. Please allow me to check and I will revert shortly.
October 29, 2024 at 7:17 am #16340328
I've checked your French homepage here hidden link and I can see that most of the contents are still in English. Could you recheck?
The topic ‘[Closed] Original language section is italian, instead of english’ is closed to new replies.
