Last updated by andreasM-70 2 months ago.
Assisted by: Maiya AI Support.
November 28, 2025 at 11:18 pm #17619106
andreasM-70
Site owner
I am trying to access a custom post type listing via the WordPress backend.
Custom post type overview loading took nearly 3 minutes to load.
Posts overview is also slow.
We're using PHP 8.3 and automatic translations.
I have used Query Monitor, which suggests that the issue is caused by a slow WPML query.
I've followed multiple recommendation of yours to increase performance – but none of them have anything to do with the backend queries, so did not help. I've attached screenshots of the Query Monitor.
Why is the post listing taking so long to load?
How can this be fixed?
My customer is understandably upset that he can't easily edit his posts due to long wait times.
On a side note.. there's 306 PHP Errors that could probably be avoided on your end (see screenshot attached).
Here's the query that causes a long wait time on my custom post type listing (see screenshots attached):
SELECT translations.translation_id, translations.element_type, translations.element_id, translations.trid, translations.language_code, translations.source_language_code, (
SELECT element_id
FROM wp_icl_translations as originalTranslation
WHERE originalTranslation.trid = translations.trid and originalTranslation.source_language_code IS NULL ) as original_doc_id, NULLIF(translations.source_language_code, '') IS NULL AS original, translation_status.rid, translation_status.status, translation_status.translator_id, translation_status.needs_update, translation_status.review_status, translation_status.translation_service, translation_status.batch_id, translation_status.timestamp, translation_status.tp_id, translation_status.ate_comm_retry_count, jobs.max_job_id as job_id, jobs.translated, jobs.editor, jobs.editor_job_id, jobs.automatic, jobs.ate_sync_count
FROM wp_icl_translations as translations
LEFT JOIN wp_icl_translation_status translation_status
ON translation_status.translation_id = translations.translation_id
LEFT JOIN (
SELECT MAX(job_id) as max_job_id, translated, editor, editor_job_id, automatic, ate_sync_count, rid
FROM wp_icl_translate_job
GROUP BY job_id ) as jobs
ON jobs.rid = translation_status.rid
WHERE translations.trid IN (
SELECT trid
WHERE (element_id = 838964
AND element_type = 'post_trend')
OR (element_id = 838923
OR (element_id = 838199
OR (element_id = 838189
OR (element_id = 838182
OR (element_id = 838112
OR (element_id = 838099
OR (element_id = 838082
OR (element_id = 838060
OR (element_id = 655807
OR (element_id = 655802
OR (element_id = 645688
OR (element_id = 642861
OR (element_id = 637813
OR (element_id = 637810
OR (element_id = 635531
OR (element_id = 634057
OR (element_id = 634053
OR (element_id = 634056
OR (element_id = 634052
OR (element_id = 634051
OR (element_id = 634048
OR (element_id = 634047
OR (element_id = 634046
OR (element_id = 634043
OR (element_id = 634042
OR (element_id = 634041
OR (element_id = 634040
OR (element_id = 634039
OR (element_id = 634038
OR (element_id = 634005
OR (element_id = 633999
OR (element_id = 633998
OR (element_id = 633997
OR (element_id = 633996
OR (element_id = 633995
OR (element_id = 633994
OR (element_id = 633993
OR (element_id = 633992
OR (element_id = 633991
OR (element_id = 633990
OR (element_id = 633989
OR (element_id = 633988
OR (element_id = 633987
OR (element_id = 633986
OR (element_id = 633985
OR (element_id = 633984
OR (element_id = 633983
OR (element_id = 633982
OR (element_id = 633981
AND element_type = 'post_trend') )
AND 1 = 1
The topic ‘[Closed] Posts overview loading takes more than 2 minutes’ is closed to new replies.
