Last updated by Marcel 3 weeks ago.
Assisted by: Marcel.
April 1, 2026 at 6:51 pm #17944205
Alberto Pagura
Hello, today after update i get problem, i don't see title and description translated on my website, title of and paragraph atomic elementor v4.
the fields on popup editor task are translated, but in page i don't see anything, isee blank fields! i try to update with elementor editor and update page, and after that i see theese filds on front end in default site language, example in italian
It worked until today before the update of wpml
April 1, 2026 at 7:01 pm #17944272
Alberto Pagura
hello, and on the strings i see example package-string-2-4987, and where i see package string, theese are all atomic fiends and don't work, how i can resolve?
April 3, 2026 at 1:35 pm #17948039
Marcel
Just to confirm: the fields appear in the translation editor, but not on your frontend—did I understand that correctly? Also, do you have a staging site where I could take a look?
I would eventually also need to request temporary access (WP-Admin and FTP) to your site
in order to be of better help and check if some configurations might need to be changed
✙ I would additionally need your permission to de-activate and re-activate Plugins and the Theme, and to change configurations on the site. This is also a reason the backup is really important.
✙ Please add the Links to the […] Edit Screen, the Page/Post where you insert the […] and the corresponding Front End Page/Screen
Best Regards,
Marcel
The topic ‘[Closed] Problem after update with atomic widget of elementor V4’ is closed to new replies.
