You are experiencing a 404 error when trying to access a translated page on your website.
We recommend enabling the Redis Object Cache plugin on your site. After enabling it, navigate to Tools > Redis > Flush cache. This should resolve the issue and display the translated page correctly.
If this solution does not apply because it's outdated or not relevant to your case, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the problem persists, please open a new support ticket at WPML support forum for further assistance.
Last updated by Long Nguyen 10 months, 1 week ago.
Assisted by: Long Nguyen.
October 2, 2024 at 6:54 am
yuryB-5
I have a problem with the translated page hidden link. If you change the URL of this page by at least 1 character, it will be displayed. Under this URL, it shows a 404 error.
404 error when accessing the translated page at hidden link
Why does the translated page show a 404 error?
How can I fix the 404 error on the translated page?
October 2, 2024 at 7:42 am
October 2, 2024 at 7:55 am #16243728
yuryB-5
Is the copy made by the duplicator taken from the site? How long will it take to solve the problem? Can I continue to edit the site ? Will I not interfere with the investigation?
October 2, 2024 at 9:24 am #16244367
Long Nguyen
WPML Supporter since 02/2022
I'm trying to investigate the issue, I will update you here when I have more information. Meanwhile, you can continue editing your site as well.
October 2, 2024 at 9:51 am #16244577
Long Nguyen
After restoring your site on my local host, I don't see the issue, please check the attached screenshot.
There could be a caching issue or something else on your hosting, can you please contact your hosting support and ask them to check the URL on your site?
October 2, 2024 at 9:55 am #16244598
Long Nguyen
On your site, I enable the plugin Redis Object Cache then go to Tools > Redis > Flush cache. Now you can see the FAQ in the Russian language displayed properly.
October 2, 2024 at 9:58 am #16244691
yuryB-5
Unbelievable, thank you
