The client is unable to navigate from the French version of the events page to the English version using the Events Calendar plugin. Additionally, the layout of the English page is disrupted.
We recommend deleting the translated events page from
Page > All
, and also removing it from the trash. Afterwards, go to the default language events page and re-translate it. This should resolve the navigation and layout issues.
If this solution does not apply to your situation, or if it seems outdated, please check the related known issues and confirm that you have installed the latest versions of your themes and plugins. If problems persist, we highly recommend opening a new support ticket at WPML support forum for further assistance.
Last updated by julieb-9 7 months, 3 weeks ago.
Assisted by: Dražen.
August 4, 2025 at 9:22 pm #17294765
julieb-9
I am trying to link the events page in French and English on my site hidden link. The page is created by the Events Calendar plugin and not found in the PAGES section of the dashboard. The plugin settings ask for a permalink.
I can't navigate to the English version of the events page from the French page, but I can access the French page from the English page. The English page layout is messed up.
How can I link the French and English events pages correctly?
Why is the English page layout messed up?
August 6, 2025 at 10:12 am #17299044
Dražen
thanks for contacting us.
I am not sure how did you create and translate the Events page, but best would be to delete the translated page from Page > All, and then remove it from trash also.
Then go to your default language Events page and re-translate it.
It should be fine then, let me know how it goes.
Drazen
August 6, 2025 at 12:17 pm #17299409
julieb-9
It's not even in the Pages. I have no idea where I can find it and delete it. Can you help?
August 6, 2025 at 12:28 pm #17299441
Dražen
Okay, maybe I have misunderstood your issue.
I have just checked, and I can see and switch language fine on both EN and FR events page:
- hidden link
- hidden link
Can you please explain what is exactly the issue and steps to see the problem?
Drazen
August 6, 2025 at 12:33 pm #17299454
julieb-9
Wow its fixed itself haha thanks
