Last updated by magdalenaP-11 2 years, 3 months ago.
Assisted by: Osama Mersal.
April 8, 2023 at 8:05 pm #13432099
magdalenaP-11
I use PPOM plugin to add some option in products and I noticed that this option do not show in translated contents
April 9, 2023 at 11:59 am #13434001
Osama Mersal
WPML Supporter since 02/2020
Thanks for contacting WPML forums support.
This ticket seems to duplicate another ticket, so please close this ticket, and continue fixing the issue on the other one. (https://wpml.org/forums/topic/ppom-fields-do-not-show-in-translated-product/)
Thanks for your understanding
Osama
April 9, 2023 at 12:07 pm #13434021
magdalenaP-11
Could you help me Please?
April 9, 2023 at 12:13 pm #13434049
Osama Mersal
1) Sure, I'll do my best to help you fix the issue. Please login to this sandbox site and install the PPOM plugin. (hidden link)
After that, please try to replicate the issue. If the issue is replicable, please let me know how to reproduce it.
The debug info will give me a lot of information about how your site is configured.
Osama
April 10, 2023 at 3:35 pm #13438067
magdalenaP-11
Hello, I was trying to make changes to the PPOM plugin, but unfortunately I could not - the changes did not save
April 10, 2023 at 3:56 pm #13438195
Osama Mersal
Please let me know the steps to reproduce the issue. It would be great if you could provide a screen-recorded video while replicating the issue.
I created and translated a test product to check the issue, but the fields appear in all languages. (hidden link)
Please don't forget to attach the fields to the translated products after translating the default language product. (Kindly check the attached screenshot)
Osama
April 11, 2023 at 6:14 pm #13449305
magdalenaP-11
PPOM fields show only in Polish language - when I change language to English thare are no PPOM fields in any product in English. Secondly, I was trying to attach the fields to the translated products after translating the default language product, but unfortunately there is a communicat: No matching records found (for example when I enter Bracelet, although I have translated product Bransoletka (PL) in English). I noticed (when I change language from Polish to English) that in English version i do not have all of products shown in my store.
I will be grateful for help
April 11, 2023 at 6:20 pm #13449411
Osama Mersal
Thanks for your update. I would need to look closely at your site, so I would need to request temporary access (WP-Admin and FTP)
Your next answer will be private, which means only you and I can access it.
Osama
April 13, 2023 at 6:24 pm #13467489
magdalenaP-11
Hello, is this answer still private?
April 14, 2023 at 12:20 am #13469219
Osama Mersal
Your next answer will be private to share the access details safely.
Osama
April 14, 2023 at 10:14 am #13472563
Osama Mersal
1) I checked the issue and found that the English products don't have fields group selected. (Kindly check the attached screenshot)
After selecting the fields and updating the product, the fields appeared correctly on the front end. Kindly check this product where I applied these steps. (hidden link)
Please let me know if that fixed the issue.
2) In our forum, we try to keep one issue per ticket, so may I kindly ask you to open a new ticket for your additional question (Bestsellers issue)?
Continuing with one ticket per issue helps supporters focus on one issue at once and enables other users to find solutions to their questions faster.
Osama
April 16, 2023 at 6:44 pm #13482259
magdalenaP-11
Hello
my previous problem has been resolved, so thank you for your help, but I noticed that not all PPOM fields appear in the English product. Examples: It is possible to choose an engraver in the product. When I choose "any inscription" it should show a field when the customer can enter some text or field, when the customer can choose the place where I have to make an engraving (loop or collar). Works in Polish, but does not work in product English.
Secondly: I have a few PPOM fields with prices in PLN. Where can I translated (convert) it to euro?
Thank you
April 16, 2023 at 9:55 pm #13482615
Osama Mersal
In our forum, we try to keep one issue per ticket. As the original issue is resolved, may I kindly ask you to open a new ticket for your additional question?
Osama
April 17, 2023 at 3:45 pm #13489339
magdalenaP-11
Thank you!
