The client is experiencing incorrect product quantities displayed next to the WooCommerce product filter in languages other than the default language on their website.
To address this issue, follow these steps:
- Navigate to Products -> Attributes.
- Click "Configure terms" to access the "Kompatybilność" attribute terms.
- Click on the number of products next to the problematic term to view all products in this term.
- Select all products.
- From the "Bulk Actions" dropdown menu, choose edit.
- Change the status to "Publish" and update them.
If these steps do not resolve the issue or if the solution seems outdated or irrelevant to your specific case, we recommend opening a new support ticket. We also highly recommend checking related known issues at WPML Known Issues, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. For further assistance, please visit our support forum at WPML Support Forum.
This topic contains 20 replies, has 2 voices.
Last updated by przemyslawD-3 1 year, 6 months ago.
Assisted by: Osama Mersal.
September 3, 2024 at 10:57 am #16135104
Osama Mersal
1) Please check the following steps:
1- Go to Products-> Attributes
2- Click "Configure terms" to go to the "Kompatybilność" attribute terms
3- Click on the number of products besideshidden link"> the problematic term
4- You will see hidden link">all products in this term
5- Select all of them
6- Select edit from the "Bulk Actions" dropdown menu
7- Change the status to "Publish" and update them
2) Please translate hidden link">this string and let me know if it fixed the issue.
Also, you would need to translate hidden link">this one.
Osama
September 3, 2024 at 11:09 am #16135171
przemyslawD-3
ad 1) Thank you.
ad 2) Ok, now it works in Swiss version. But how is it possible that it also works in Polish and French, since there is no translation?
Ad 3) And how to fix this woocommerce .mo buffering?
September 3, 2024 at 11:47 am #16135379
Osama Mersal
1) They work because these languages have MO and PO files.
2) I'm not sure why it's stuck on your site, but I tested it on a test site, and it worked correctly.
Osama
September 3, 2024 at 12:41 pm #16135720
przemyslawD-3
Ok, I will be try to translated all otherthings and will be back with new topic if other problem. One more thing: where is translation from revslider? I can't choose any language after all of this change.
September 3, 2024 at 12:47 pm #16135776
Osama Mersal
We try to keep one issue per ticket in our forum, so may I kindly ask you to open a new ticket for the slider issue?
Continuing with one ticket per issue helps supporters focus on one issue at once and enables other users to find solutions to their questions faster.
Thanks for your understanding
Osama
September 3, 2024 at 1:00 pm #16135811
przemyslawD-3
ok
