Last updated by janW-44 1 year, 8 months ago.
Assisted by: Noman.
September 3, 2024 at 8:58 am #16134500
janW-44
I have 6 WooCommerce shops linked together using WooMultistore. The ‘mother’ shop and one of the shops use WPML. So far everything has worked fine. Prices, descriptions were synchronising between the shops.
From a certain point on, the synchronisation started to work only for the shops using WPML. After disabling the WPML plugin on the ‘mother’ shop, the synchronisation works for all shops.
Why did the synchronization stop working for non-WPML shops?
How can I fix the synchronization issue without disabling WPML on the ‘mother’ shop?
The topic ‘[Closed] Problem with Woomultistore with WPML enabled’ is closed to new replies.
