Issue:
When you try to translate categories on your site using WPML, you notice that the categories display an incorrect total number of products when you switch to English.
We have found that the problem occurs because the products are not translated, and the default language products are displayed instead. If you wish to use the translated categories/filters, you will need to translate the products.
If this solution is outdated or does not apply to your situation, please visit the Related Known Issues, verify that you have the latest versions of your themes and plugins installed, and check for permanent fixes. If the problem persists, we recommend that you open a new support ticket.
Last updated by 1 year, 3 months ago.
Assisted by: Dražen.
