Supporter timezone: Africa/Cairo (GMT+02:00)
Last updated by homeP 6 hours, 21 minutes ago.
Assisted by: Osama Mersal.
January 18, 2026 at 6:38 pm #17740611
homeP
Problems with displaying languages ​​in the header custom space
January 18, 2026 at 8:52 pm #17740669
Osama Mersal
WPML Supporter since 02/2020
You can add the language switcher using the shortcode in this location using the shortcode Elementor widget. Kindly check this guide to know more about adding switchers using shortcode.
Osama
January 20, 2026 at 8:04 am #17744813
homeP
Hey Osama,
Thanks for the instructions, but it doesn't work. It's a new theme, and I'm assuming the author will again claim it's 100% compatible with WPML, but in reality, it's definitely not compatible. It's always the same theme with these same authors.
Send me a private message, and I'll send you my login details.
January 20, 2026 at 9:04 am #17745057
Osama Mersal
I've enabled the private reply. Please share the access details, and I'll try to add the language switcher.
Osama
January 22, 2026 at 8:50 am #17752713
homeP
There are still problems with the footer. We're using Footer Style 2. Footer Style 2 is not visible.
New threads created by Osama Mersal and linked to this one are listed below:
https://wpml.org/forums/topic/cannot-translate-footer-or-header-or-contact-form/
January 22, 2026 at 8:53 am #17752736
homeP
January 22, 2026 at 8:55 am #17752782
homeP
We cannot translate "Footer" or "Header" or "Contact Form"! An error message appears.
January 22, 2026 at 9:05 am #17752796
Osama Mersal
1) I added the language switcher via shortcode, but it doesn't display correctly on the front end. (Kindly check this hidden link">screenshot)
Please let me know if you use any custom CCS for the header.
If not, please install your theme on this hidden link">Sandbox site and replicate the issue.
If the issue is replicable, please let me know, so I can check it and consult our compatibility team.
2) We try to keep one issue per ticket in our forum. Continuing with one ticket per issue helps supporters focus on a single issue at a time and enables other users to find solutions to their questions faster.
Therefore, I've split the other issue and created a new ticket for this issue.
Osama
January 23, 2026 at 4:03 pm #17757831
homeP
Hey Osama,
You can work on our site; I just made a manual backup. The site isn't live yet.
Additionally, the theme is installed in a sandbox.
January 23, 2026 at 4:06 pm #17757834
homeP
We haven't created any custom CSS for the header. Only the background color CSS for the sticky header is used.
