- 8:00 – 10:00 8:00 – 10:00 8:00 – 13:00 8:00 – 13:00 9:00 – 13:00 -
- 11:00 – 17:00 11:00 – 17:00 14:00 – 17:00 13:00 – 17:00 13:00 – 18:00 -
Supporter timezone: America/New_York (GMT-05:00)
This topic contains 12 replies, has 0 voices.
Last updated by zakW 2 months ago.
Assisted by: Lauren.
February 11, 2026 at 4:42 pm #17813768
zakW
Product Bundles with variations not showing options in other languages, only in the main one
This is an example:
EN - hidden link
FR - hidden link
I know the bundle is working for other bundle products when the only have simple products added.
February 11, 2026 at 4:54 pm #17813851
Lauren
Please let me know if running the product and variations sync after updating plugins resolves the issue. If not, we will be happy to further troubleshoot. Thanks!
February 12, 2026 at 9:10 am #17815561
zakW
Hi Lauren,
I hope you are well.
I have update the WPML plugins and done the clean up you suggested but the bundle product I mentioned before is still not showing its options in other languages besides the main one
Kind Regards
Ruben
February 13, 2026 at 3:40 pm #17821273
zakW
Hi Lauren,
Do you have an update on this for me?
Kind Regards
Ruben
February 13, 2026 at 4:26 pm #17821380
Lauren
Thanks for the update about the troubleshooting syncrhonization. Please try these next steps. Go to WooCommerce -> WooCommerce Multilingual -> Status and scroll down to the Troubleshooting link. Once that opens you should see some checkboxes with items to sync. Make sure you have a full back up and run through all the steps here. Then, update an original language product (make any small change and save) and then update/save the translation as well. Let me know if this shows the variations on the bundles. If not, next steps would be to test minimal settings, meaning only WPML plugins active (with WooCommerce of course) and a default theme to rule out any conflicts. This is best tested in a staging site. If you don't have a staging site, we can set one up for you.
February 19, 2026 at 9:11 am #17835070
zakW
Hi Lauren,
I have checked the WooCommerce -> WooCommerce Multilingual -> Status Troubleshooting link, and I have ticked the boxes and run the updater. Did not help.
I have updated the main product as well, and the text I updated is showing in the other languages, but the bundles are still not showing.
I have tried in a staging environment the plugin and theme test, but that didn't fix the issue either.
This is the product in question, I forgot to send it before - hidden link
Would it be better for you to get access to our staging environment and see what is happening?
Kind Regards
Ruben
February 19, 2026 at 4:33 pm #17836752
Lauren
Our Debugging Procedures
Privacy and Security Policy
**IMPORTANT**
February 23, 2026 at 9:00 am #17841985
zakW
Hi Lauren,
Can you please let me know when you hope to start working on this?
I just need to know a timeline so I can let my client know
Kind Regards
Ruben
February 23, 2026 at 7:36 pm #17844261
Lauren
I've been working on the issue but have yet to find a solution. I found some custom fields related to the bundled products that had been set to Not Translatable. I set those to Copy and saved the product, but that didn't automatically resolve the problem. I'd like to have you try a few things. Please be sure to make a full backup of your site and database.
Then, go to WPML -> Support -> Troubleshooting.
Look for 'Clean up' and click the following:
- Synchronize posts taxonomies
- Clear the cache in WPML
- Fix element_type collation
- Set language information
- Synchronize local job IDs
- Fix Terms count
- Fix post assignment for translations
If that doesn't fix it, , please go to WooCommerce → WooCommerce Multilingual → Status → Troubleshooting
Run:
✔ Sync product data
✔ Sync variations
✔ Synchronize attributes and product relationships
This forces WPML to re-associate the bundled product IDs in the secondary language.
If that does not resolve the issue, let's try editing the translated product manually just to test if manually adding a bundled product works, because I can see that there are no bundled products when I edit the US product here: hidden link
Please let me know if you prefer me to run these tests for you and I will be happy to continue troubleshooting.
February 25, 2026 at 1:19 pm #17851646
zakW
Hi Lauren,
I will action this in my next maintenance time for the website that is scheduled for Friday.
As soon as I have this completed, I will let you know my findings to see if we still need assistance or not
Kind Regards
Ruben
February 25, 2026 at 2:12 pm #17851842
Lauren
Okay sounds great, I'll look forward to your update on Friday.
March 2, 2026 at 8:52 am #17863693
zakW
Hi Lauren,
There was a bit on an issue with scheduling on my side, and the work will be carried out this week.
I will let you know once the work is completed and if the bundles with variations are working in translated products
Kind Regards
Ruben
March 5, 2026 at 9:16 am #17874087
zakW
Hi team,
We are still to work on this matter.
Will keep you updated once I work on it
Kind Regards
Ruben
The topic ‘[Closed] Product Bundles with variations not working correctly’ is closed to new replies.
