You are trying to display translated and published products in the second language on your site, but the products do not show in the second language.
We recommend activating the WooCommerce Multilingual plugin to resolve this issue. After activation, please check your translated shop page to ensure that it works correctly.
If this solution does not apply to your case, or if it seems outdated, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If issues persist, please do not hesitate to open a new support ticket with us for further assistance.
Last updated by konstantinosP-21 1 year, 1 month ago.
Assisted by: Osama Mersal.
March 9, 2025 at 5:08 pm #16793361
konstantinosP-21
I am trying to display translated and publish products in the second language on my site hidden link.
Products do not show on the second language.
Why are the products not showing in the second language?
How can I display translated products in the second language?
March 9, 2025 at 6:05 pm #16793462
Noman
Before your ticket is assigned to one of my colleagues, I'd like to guide you through some initial debugging steps to speed up the support process.
To begin, please follow the below steps and let us know how it goes:
1. Take a backup of your site first for safety reasons.
2. We have recently released WPML 4.7.1, please update it to the latest version. You can update it from Plugins >> Add New Plugin page, click the Commercial tab, and then click the “Check for updates” button. Here is the screenshot for more details:
https://wpml.org/wp-content/uploads/2020/04/wpml-force-plugin-update-1.png
3. Please make sure to install the WooCommerce Multilingual & Multicurrency plugin which is required to make WooCommerce plugin multilingual, if the WPML is registered properly on your site you should be able to download it from Plugins >> Add New plugin > Commercial tab, or directly download it from WPML.org downloads page: https://wpml.org/download/woocommerce-multilingual-multicurrency/
3. After installing WooCommerce Multilingual & Multicurrency plugin, please configure it by following the below doc: https://wpml.org/documentation/related-projects/woocommerce-multilingual/#plugins-you-need
4. If the issue persists, please try to follow the below procedure:
4.1. Open the default language product in Edit mode.
4.2. Make a small change, for example, add a space or + sign in your product title.
4.3. Update the product by pressing the “Update” button.
4.4. Now, please remove that small change that did in step #4.2.
4.5. Update the product again.
4.6. Now, please try to open the translated page in WPML Translation Editor and make sure the translation is 100% complete and press the complete translation button.
5. If the above steps don’t help, please share the page/product link where we can see the issue.
Kindly let us know the results,
Thank you
March 10, 2025 at 2:34 pm #16797086
konstantinosP-21
Hello tried all above you suggested, though there is still the same problem, please see below page:
this is the original page in English, which works fine
Please let me know if you need username/password to have a closer look.
Kind regards
Konstantinos
March 11, 2025 at 4:16 am #16799250
Osama Mersal
I'm Osama from WPML forums support. I'll be glad to help you today.
I would need to look closely at your site, so I would need to request temporary access (WP-Admin and FTP)
❌ Please back up your database and website ❌
Osama
March 11, 2025 at 7:51 am #16799716
Osama Mersal
Thanks for the access details. I activated the "WooCommerce Multilingual" plugin, which fixed the issue.
Please check the translated shop page and let me know if it works correctly. (hidden link)
Osama
March 11, 2025 at 8:11 am #16799834
konstantinosP-21
Thank you so much for your prompt support!
