If you're using WPML to automatically translate products on your site and find that the products aren't being translated despite having the 'Translate Everything Automatically' feature active, and you're wondering if changes to product details like title, URL, or description will automatically translate as well, here's what you need to check.
First, ensure that the 'Translate Automatically' option is enabled for the 'Product' post type. Follow these steps:
1. Navigate to WPML > Settings.
2. Scroll to Post Type Translation.
3. Set the translation preference for the 'Product' post type to 'Translatable - only show translated items'.
4. In the 'Translate Automatically' column, toggle the switch to 'Yes'.
5. Save the changes.
Additionally, if the Automatic Translation feature is active, any changes you make to the default product details will also be automatically translated.
If this solution does not resolve your issue, or if it seems outdated or irrelevant to your specific case, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If further assistance is needed, please open a new support ticket at WPML support forum.
Last updated by 1 year, 6 months ago.
![16329644-1gjdUfp[1].png](https://cdn.wpml.org/wp-content/uploads/2024/10/16329644-1gjdUfp%5B1%5D-150x150.png)
