Last updated by selwynH 11 months, 2 weeks ago.
November 26, 2024 at 9:06 am #16443361
selwynH
I see. Do you have any idea on how to debug this issue if this is the case? I’ll run tests on my end.
I noticed that it deleted all the properties that were there? There were 87 Hebrew properties and now there are 13. Can you check?
November 26, 2024 at 9:44 am #16443695
selwynH
Heres the thing. I think the import deleted all posts that were not present in the import (for whatever reason- this needs to be checked of course!)
So I thought, run an export of all the properties (En + He) then rerun the import and map the export so all the custom data (such as content, permalinks, images) are applied. However when I tried this, it broke and nothing was imported correctly.
This may be the best solution (ie to start with 2 fresh imports of data) but the issue still stands regarding both points. Please urgently assist
November 26, 2024 at 9:56 am #16443757
selwynH
I can restore a backup of the site before the import was run yesterday to get it to the state of production is currently so the original issue can be replicated if need be
