You have a website with Arabic translations enabled using WPML, and you've noticed that the URLs have been auto-translated into Arabic. You want to revert these URLs back to their original English versions across the site.
If you're experiencing this issue, we recommend you follow these steps:
1. Navigate to WPML-> Settings-> Translated documents options-> Page URL.
2. Select the "Copy from original language if translation language uses encoded URLs" option.
3. Click "Save".
4. Go to WPML-> Languages-> Edit Languages.
5. Set "Yes" in the Encoded URL dropdown menu in the Arabic column.
6. Click "Save".
7. Create a new test page and translate it to verify that the slugs are copied correctly.
For existing pages, make a minor edit and update them in the default language, then update the translation using the translation editor.
This solution might be irrelevant if it’s outdated or not applicable to your case. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If this does not resolve your issue, please open a new support ticket at WPML support forum.
Last updated by 11 months, 1 week ago.
Assisted by: Osama Mersal.
