This topic contains 5 replies, has 1 voice.
Last updated by Bobby 1 year ago.
Assisted by: Bobby.
March 18, 2025 at 5:13 pm #16831828
platinumC
I am trying to use the search functionality on my WordPress site, hidden link, which uses WPML. I am specifically working with the Arabic section of the site at hidden link.
When I write in English in the search bar on the Arabic section of the site, it does not return English search results.
Why does the search in the Arabic section not return English results when I search in English?
March 18, 2025 at 10:44 pm #16832802
Andrey
WPML Supporter since 06/2013
One of my colleagues will handle your ticket. In the meantime, I would like to share some helpful information.
This behavior is expected because the content is organized by language. You won't also see Arabic results on the English version of the site. This cannot be changed in the WPML settings, and it requires the custom coding for your current theme if the search is part of it.
March 19, 2025 at 5:40 am #16833213
platinumC
in english if i write arabic the result is arabic and in arabic if i write english the result is also arabic .. plz check
March 19, 2025 at 9:40 pm #16837307
Bobby
WPML Supporter since 04/2015
I just did a quick search and it worked as expected.
Please see my screenshots.
March 25, 2025 at 1:17 pm #16857859
platinumC
i mean if im in arabic ... if i write english the search do not work
March 26, 2025 at 6:54 pm #16865115
Bobby
This behavior is expected, as the search is being conducted within the Arabic content rather than the English content.
It would be the same behavior as if the products have not been translated or are displayed using the "display as translated" method (which does not correspond to an actual database ID), no results will be returned.
The topic ‘[Closed] search problem in wpml’ is closed to new replies.
