Last updated by Dražen 1 year, 11 months ago.
Assisted by: Dražen.
April 10, 2024 at 10:05 am #15503608
sophiaB-2
I am trying to: Use PHP created ACF fields with the relevant wpml_cf_preferences parameter to set which fields are set to translate.
When trying to translate any page, we can use "What we do" as an example, only the page title shows up as available to translate.
I expected to see:
All fields that were set to
'wpml_cf_preferences' => 2
to show up for translation when I go to translate any page. I also expected to see the fields that were set to
to show up as set to "Translate" on the settings page under Custom Fields Translation.
Instead, I got:
Nothing. No fields are available to translate when trying to translate pages and on the settings page under Custom Fields Translation, all are set to "Don't translate"
April 11, 2024 at 11:14 am #15508740
Dražen
thanks for contacting us.
Since I see you are using some custom theme, can you please try to test it with the WP default theme? Add one part of your code for ACF there and see if those custom field translation settings are now being correctly set and shown. I suggest checking this on the staging site.
Do not forget to sync changes:
- hidden link
Let me know how it goes.
Drazen
April 11, 2024 at 1:28 pm #15509537
sophiaB-2
I fixed this myself. Thanks.
