Last updated by Logothetis 11 months, 4 weeks ago.
Assisted by: Otto.
| Author | Posts |
| March 14, 2025 at 7:49 am #16814741 | |
Logothetis |
| March 17, 2025 at 12:52 pm #16824729 | |
Otto |
Hello, I apologize for the delay in answering. I will take care of this ticket and reply time will be shorter now. When the user is not logged in, caching may not be applied and that may be a reason. But we need to find the root cause, which I think it may be a compatibility issue. I suggest you try this to help us identify if it might be a conflict with another plugin or theme that is causing the problem. Let me know your results, please. Best Regards, |
| March 19, 2025 at 10:59 am #16834503 | |
Logothetis |
Hello, Otto, I have already created a staging site and followed your suggestion. |
| March 19, 2025 at 1:09 pm #16835401 | |
Otto |
Hello, Thanks. I would like to request temporary access (wp-admin and FTP) to your site to take a better look at the issue. The information you will enter is private which means only you and I can see and have access to it. **IMPORTANT** |
| March 20, 2025 at 2:17 pm #16840513 | |
Otto |
Hi, Thanks! I logged in and visited the page you provided and it loads pretty fast for me. Please check this screencast: Am I missing something? Can you please provide me with the steps to see the problem? Best Regards, |
| March 21, 2025 at 6:27 am #16842639 | |
Logothetis |
Hello Otto, While you are logged in, visit the page hidden link. The page opens normally, but when you try to go to page 2 or 3 using the pagination buttons, the load time is very long. |
| March 21, 2025 at 12:25 pm #16844361 | |
Otto |
Hello, Thanks for clarifying. I tested it on your staging site and with any WP default theme, the issue is no longer happening. With the Sevenloft Eshop parent theme, the performance seems to be a bit worse but not terrible. Can you please confirm? Best Regards, |
| March 24, 2025 at 7:32 am #16849896 | |
Logothetis |
Hello Otto, It seems the issue is with the Sevenloft Eshop Child theme. I tested it with the default theme and the Sevenloft parent theme, and it seems fine. I didn’t know why I hadn’t seen that. Thank you for your help. |
