The client reported that the buttons on their website were displaying in Dutch ('meer info') instead of Polish, despite the website being set to Polish.
We identified that the issue was related to the Divi Events add-on. We recommended removing any custom 'read more' text so that the default text from the add-on could be translated. We advised the client to use the WPML String Translation tool to find and translate the default add-on text. The relevant section can be accessed via WPML > String Translation, searching under the domain 'decm-divi-event-calendar-module'.
If this solution does not resolve your issue, or if it seems outdated or irrelevant to your case, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If further assistance is needed, please do not hesitate to open a new support ticket at WPML support forum.
Last updated by milcoP 7 months, 1 week ago.
Assisted by: Dražen.
September 29, 2025 at 1:18 pm #17441132
milcoP
YES, perfect. Thank you
brings be to the other problem.
The buttons were in english 'more info' but they are in dutch now; 'meer info'.
But they supposed to be polish.
see for example:
what can i do about that?
September 29, 2025 at 1:28 pm #17441208
Dražen
lest continue in this ticket.
I have checked and can see this is coming from Divi Extra module, I will need to further check on this and try to make it translatable.
Please keep your staging site as I will be checking there.
I will update when I have some news.
Drazen
September 29, 2025 at 2:01 pm #17441360
milcoP
Perfect, thank you.
September 30, 2025 at 6:23 am #17442640
Dražen
I checked and actually this is coming from Divi Events add-on. I have removed your custom read more text and you can then translate default add-on text from WPML > String translation under domain decm-divi-event-calendar-module
- hidden link
You can check the text and translate how you wish.
Drazen
September 30, 2025 at 1:25 pm #17444929
milcoP
Thank you very much.
this worked.
