Supporter timezone: Europe/Zagreb (GMT+01:00)
Last updated by Dražen 8 months, 4 weeks ago.
Assisted by: Dražen.
June 19, 2025 at 10:39 am #17149993
pavelK-20
Thank you, Album Base Listing now shows album cover and Name, but, Artist, group and release date is not shown. Is WPML compatible with Dynamic Link and Dynamic Fiel from Crocoblock Jet Engine? Please, why in czech language it is shown and in englis not?
June 19, 2025 at 10:46 am #17150026
Dražen
I checked further and it seems you have added this as custom field for Product custom type, but you also need to follow related docs for this part as explained here:
- hidden link
You need to set related custom fields to copy / translate and re-translate, and note as it says that you may need to edit your 2nd language manually and add custom fields value if needed.
Drazen
June 21, 2025 at 10:02 am #17155805
pavelK-20
Now even Czech Product Listing is broken. It was in English, that no release date nor no artist was shown in listing. Now issue extends to primary language. Why? What was changed?
I checked Meta items and none of them should by translated. So it is set.
June 23, 2025 at 5:35 am #17157933
Dražen
I did not change or do anything at that part, I am not sure why Czech not working, you can check further without WPML and make sure it works fine in default.
Even if they are not to be translated the custom fields need to be set COPY or you need to edit your 2nd language product manually and set values for those fields, otherwise they will be empty in 2nd language.
Drazen
June 24, 2025 at 4:58 am #17162927
pavelK-20
I set all product meta field as "Copy" but nothing changed.
So I tried switch off WPML. And suddenly every album is twice in listing.
Album Listing is still broken. Please, why is every album listed twice and why album listing is not working even in czech. It was all goog before I installed WPML.
June 24, 2025 at 6:34 am #17163087
Dražen
it is twice because now when you disable WPML you see all language listing, there is no more language information.
As for issue in your default language, Czech, you will need to check further and make sure it works fine without WPML, since I have not changed anything that touched, also it should work fine in default language first before we can check why is not working in 2nd language.
You can also check with JetEngine support, and make sure it works fine when WPML is disabled, then if issue is only on translated language I can further debug and see what is wrong from WPML / translation side.
Drazen
June 25, 2025 at 4:43 am #17167072
pavelK-20
It was fully functional before i installed WPML. I did not changed anything too. May by, tahat issue is related to staging environment? I don't know. I will try to push changes to dev environment. And if it will be broken, I will restore version befor WPML and will try another rouund of installing WPML. Any other idea?
June 25, 2025 at 8:58 am #17167816
Dražen
I am not sure to be fair, I can only guess that might some settings in Jetengine listings / templates where changed.
If issue is caused by WPML; if you disable WPML it should work fine, if still not then it is not caused by WPML, probably something else caused it.
Let me know how it goes and if any else we can do for you.
Drazen
The topic ‘[Closed] Split: Dynamic Link and Dynamic Fiel from Crocoblock Jet Engine’ is closed to new replies.
