This topic is split from https://wpml.org/forums/topic/wpml-elementor-woocommerce-bug-2/
Last updated by Andreas W. 7 months, 4 weeks ago.
November 27, 2024 at 8:44 am #16448066 | |
christelC |
Hi, 1s it seems that the first issue that you mentioned is fixed (needs to be check for sure). 1. Header Template Translation Issue 2. When attempting to translate product category names, the following behavior is observed: lease investigate the following: |
November 27, 2024 at 12:55 pm #16449817 | |
christelC |
Hi, I would like to report an issue specifically related to translating Elementor templates via WPML. Issue Description The system displays the message "0% less than a minute remaining", but it continues to load without completing. Could you please investigate and advise on the following: What could be causing the auto-translate process to fail for Elementor templates? If the process cannot be resolved through the UI, are there manual steps I can follow to push the template translations? ==> hidden link |
November 30, 2024 at 7:13 pm #16462242 | |
Andreas W. WPML Supporter since 12/2018 Languages: English (English ) Spanish (Español ) German (Deutsch ) Timezone: America/Lima (GMT-05:00) |
Hi, It seems that the minimum requirements are not met on the server: Could you please increase the WordPress memory limit (WP Memory Limit) to at least 256 MB? WPML requires at least 128M. Your current values are: PHP MemoryLimit 256M WP Memory Limit 40M You need to connect to your website's server and open the wp-config.php file in a text editor. The file is located in the WordPress root directory. Add this code to the wp-config.php file to increase WordPress memory: define ('WP_MEMORY_LIMIT', '256M'); Add this just before this comment: // That's all, stop editing! Happy blogging. The current values can be viewed under WPML > Support > WordPress. These settings can be restricted directly by your hosting provider. Therefore, I recommend contacting them and asking them to change them directly if the changes are not applied immediately. Now, try to apply the translations again. If adjusting the limit will not solve the issue, please let us know. Best regards |
