If you're experiencing issues where translations are not displaying correctly on your website's front end, even though they appear to be added correctly, we can help you address this.
1) We recommend updating your theme and Elementor plugins to their latest versions to see if that resolves the problem. Always ensure to create a backup before proceeding with updates.
2) If updating does not resolve the issue, consider creating a staging site for further investigation. If creating a staging site isn't feasible, we can assist by making a copy of your site using the Duplicator plugin, but we will need your permission to proceed.
3) As a temporary workaround, you can adjust the code in your site. Specifically, add extra conditions in
\WPML\PB\Elementor\Hooks\QueryFilter::recursivelyTranslateQueryIds
in
/wp-content/plugins/sitepress-multilingual-cms/addons/wpml-page-builders/classes/Integrations/Elementor/Hooks/QueryFilter.php
. Here is the code snippet you can use:
if ( ! empty( $data->settings->query_include_term_ids ) ) {
$data->settings->query_include_term_ids = $this->convertTermTaxonomyIds( $data->settings->post_query_include_term_ids );
if ( ! empty( $data->settings->query_exclude_term_ids ) ) {
$data->settings->query_exclude_term_ids = $this->convertTermTaxonomyIds( $data->settings->post_query_exclude_term_ids );
if ( ! empty( $data->settings->post_query_posts_ids ) ) {
$data->settings->post_query_posts_ids = Ids::convert( $data->settings->post_query_posts_ids, Ids::ANY_POST );
// --- New cases ---
$data->settings->query_include_term_ids = $this->convertTermTaxonomyIds( $data->settings->query_include_term_ids );
$data->settings->query_exclude_term_ids = $this->convertTermTaxonomyIds( $data->settings->query_exclude_term_ids );
if ( ! empty( $data->settings->query_posts_ids ) ) {
$data->settings->query_posts_ids = Ids::convert( $data->settings->query_posts_ids, Ids::ANY_POST );
}If these steps do not resolve your issue or if the solution seems outdated or irrelevant to your case, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If needed, please do not hesitate to open a new support ticket for further assistance.
This topic is split from https://wpml.org/forums/topic/translation-errors/
