You are unable to translate the header and footer in your website.
If you're experiencing issues with translating the header and footer, it's likely due to the use of Elementor templates. We recommend checking the WPML documentation on translating Elementor templates. You can find detailed instructions here: Translating Elementor Templates.
If this solution does not apply to your case, or if it seems outdated, please open a new support ticket. We also highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins.
Last updated by Mihai Apetrei 9 months ago.
Assisted by: Mihai Apetrei.
November 18, 2024 at 7:39 pm #16416445
aslamM
how to edit header and footer ?
header and footer not translating
November 18, 2024 at 7:41 pm #16416461
Mihai Apetrei
WPML Supporter since 03/2018
Hi there.
This really depends on the theme or page builder that is being used for those templates.
But from what I can see, you are using Elementor so there's a chance the footer and header are coming from Elementor templates.
Please take a look here:
https://wpml.org/documentation/plugins-compatibility/elementor/#translating-elementor-templates
Let me know if that helped.
Mihai Apetrei
