Last updated by Andreas W. 1 year, 2 months ago.
February 1, 2025 at 9:45 pm #16659316
I can sadly not log in to the live site due to 2FA verification.
February 1, 2025 at 9:47 pm #16659319
jorgeM-44
The 2Fa was disabled. Please try again. Thank you.
February 1, 2025 at 9:54 pm #16659323
My apologies, but as we have various information with credentials on various tickets, I had to try various passwords and usernames and none worked.
According to WordPress, I have been blocked for the next 15 minutes.
Please use the private reply form and provide again access to the live site.
If you would like to set up a new admin account:
andreas.w@onthegosystems.com
February 4, 2025 at 7:37 pm #16668350
The issue seems tobe solved now.
February 4, 2025 at 8:11 pm #16668428
jorgeM-44
Hi Andreas,
I'm sorry, where? I've tested and it still doesn't work.
February 4, 2025 at 8:42 pm #16668466
I have been translating at least 5 products successfully on the live site.
Could you please provide an exact example?
February 4, 2025 at 8:50 pm #16668473
jorgeM-44
Please tell me which one. I've tested 3, and none worked.
Also can you please specify the changed made to the site?
February 4, 2025 at 11:38 pm #16668721
I connected now again to your live site and I still see 198 products that need a translation update.
I have right now completed 10 jobs. If you go to WooCommerce > WooCommerce Multilingual & Multi-Currency > Products and set the status filter to "Needs updating" you will see an amount of 188 items.
This means all 10 jobs were successful.
Could you please name examples of products that fail? (title, permalink)
February 5, 2025 at 8:30 am #16669392
jorgeM-44
Well, today it worked, tested in 2 products. It's weird. Maybe browser of my home PC? (I use edge in both pcs)
What changed did you do to the site in the last few days?
I've also updated:
- Admin and Site Enhancements (ASE)
- Google for WooCommerce
- Mailchimp for WooCommerce
- WooCommerce
I'vee then tested again and it works. Have to add more products to test out if it doesn't stop working like the previous times.
February 5, 2025 at 3:35 pm #16671987
I am glad to hear that the issue is solved.
As mentioned earlier, I have just changed the settings for a few fields at WPML > Settings > Custom Field Translation.
February 6, 2025 at 10:36 pm #16677491
jorgeM-44
Hi Andreas,
Yesterday, I added a product, and it worked perfectly!
Today, I added two new products and think I may have found a correlation.
I translated an existing product, and it worked fine. Then, I duplicated it to create a new one and also created a new customization form using the Acowebs Custom Products Addon, which I then translated. After finalizing the product where I used that new form, I translated it—but the translation didn't update.
I suspect that translating Acowebs forms might be triggering this issue. Looking back, I believe that every time this problem started happening—back in December as well—I had also created and translated new forms.
Could you please check this?
Form: [link/admin.php?page=wcpa-admin-ui#/form/47144]
Thank you, Andreas.
Jorge
February 7, 2025 at 4:03 pm #16680577
It seems like clearing the site's cache solved this issue. Please update the cache plugin and let us know if the problem occurs again.
February 7, 2025 at 4:10 pm #16680589
jorgeM-44
Are you referring to W3 total cache plugin? Maybe some options is activated?
Or do you think it's the acowebs custom products as I referred in the last message?
Can I ask how did you clean the cache?
Thank you 🙂
February 7, 2025 at 8:54 pm #16681272
Inside the admin bar, I used the option of "W3 Total Cache" to clear the cache.
February 8, 2025 at 1:02 pm #16682259
jorgeM-44
So, could this be a conflict with W3 Total Cache or Acowebs Custom Forms?
If clearing the cache temporarily resolves the issue, that could be a workaround for adding products. However, we still need a permanent solution to prevent this from happening again.
Thank you, Andreas.
The topic ‘[Closed] Split: Problem translating products when Cloudflare is active’ is closed to new replies.
