The client was facing an issue where the 'read more' text in the posts was not translating correctly using WPML, despite other text translations working fine. This issue persisted even after deactivating the Post Type Order plugin and rebuilding the template.
We identified that the untranslated 'read more' text was part of a Toolset template. To resolve this, we translated the specific text using the WPML Advanced Translation Editor (ATE) via the Translation Management section. After applying the translation directly in the Toolset template, the 'read more' button text displayed correctly in the desired language.
Please note that this solution might be outdated or not applicable to your specific case. If you're still experiencing issues, we recommend checking the related known issues, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the problem persists, please open a new support ticket.
This topic is split from https://wpml.org/forums/topic/wpml-translation-issues-on-blog-and-blog-category-pages/
Last updated by 1 year, 10 months ago.
Assisted by: Dražen.
