Last updated by Dražen 7 months, 4 weeks ago.
Assisted by: Dražen.
August 12, 2025 at 7:54 am #17312241
adamF-18
Hello
I conducted a test.
Start: 94,903 credits
1. Screen 1 - Adding a product for translation and setting. (English is set as "don't do anything")
2. Screen 2 - Error message (product has not been translated) (“Sending for translation failed”
“Tasks could not be created”)
3. Screen 3 - Reduced credits
As you can see, the only thing that can be translated on the product is the name “BPOWER START-STOP 95Ah 760A 12V P+ 335EFB 304x172x222 Battery.”
The rest are taxonomies that have already been translated. There is no description here. Other strings that appear on this subpage are global (they are translated elsewhere, not for each product separately).
Test result?
Instead of 7 credits (0 because it didn't translate), it used up 815 credits.
August 12, 2025 at 7:56 am #17312245
Dražen
lets continue here with problem job failing.
Can you please try next:
- Make sure you have a backup.
- Disable all other plugins and leave active only WPML plugins
- Switch to WP default theme
- Check if the issue still happens.
Let me know how it goes.
Drazen
August 12, 2025 at 10:06 am #17312834
adamF-18
Hi
After switching to the default theme and disabling ALL plugins (except wpml and woocommerce) - still the same error.
Before attempting translation: 94,082
After: 92,275
e2c7a48a-0916-4ffa-aa57-9ba3668bef73,08/12/25 09:59:10,153682774,1807,bulk.mt@wpml.org, hidden link
August 12, 2025 at 10:35 am #17313056
Dražen
let me take a deeper look on what is causing the issue and lets to fix it so translation can work properly.
Please share the access details of your website, so I can log in and take a look.
I’m enabling a private message for the following reply.
We have strict policies regarding privacy and access to your information.
Please see:
- Please backup the site files and database before providing us access.
Drazen
August 18, 2025 at 8:56 am #17326671
Dražen
I have checked with test post and I can see it translated and sends fine for translation.
- hidden link
Please update WCML and WC to latest version, and try again to see if the issue still happens. I can see the product you shared above (Akumulator BPOWER START-STOP 95Ah 760A 12V P+ 335EFB) is also translated fine now.
Drazen
The topic ‘[Closed] Split: Sending for translation failed” “Tasks could not be created’ is closed to new replies.
