If you're seeing multiple versions of the 'Single Posts' template in WPML under WP > WPML > Translation Management and WP > WPML > Translations, it might appear that these templates have been duplicated erroneously.
We recommend checking if these duplicates share the same ID by searching for _wp_page_template in your database. This issue might not be caused by WPML, as WPML links duplicates to the original using a trid field, and assigns different IDs to duplicates. To further investigate, try deactivating WPML temporarily after creating a full backup. If the templates still appear, they likely exist independently of WPML and can be removed directly from the database.
If this solution does not apply to your case, or if it seems outdated, please check the related known issues and confirm that you have installed the latest versions of themes and plugins. We highly recommend opening a new support ticket for further assistance at WPML support forum.
This topic is split from https://wpml.org/forums/topic/fully-translated-page-is-blank/
Last updated by 1 year, 6 months ago.
Assisted by: Marcel.
