You are experiencing issues where the body content of your website is not loading on some pages across multiple languages.
To resolve this issue, go to the page in your default language and save or update it. This action should refresh the content across all translated versions of the page.
If this solution does not resolve your issue, or if it seems outdated or irrelevant to your specific case, we recommend opening a new support ticket. Additionally, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. For further assistance, please visit our support forum at WPML Support Forum.
Last updated by Dražen 6 months, 2 weeks ago.
Assisted by: Dražen.
May 1, 2025 at 9:33 am #16986228
anandB-2
this page body is not loading
this page images are not loading
same way we have in other pages other languages
easy solution to this ?
or we have to manually go through each and every language and each and every page to see where the body of the website is not loading
May 1, 2025 at 9:38 am #16986248
Dražen
for a page with a layout missing, you need go to your default language page and save/update it.
Then it works fine:
- hidden link
Drazen
May 1, 2025 at 9:42 am #16986254
anandB-2
It appears to be the same recurring issue across multiple languages—on some translated pages, the body content of the website is not loading at all.
For example, as I’ve shown earlier (and now again with the Chinese version), the same problem persists. This suggests that the root cause—and solution—would likely be the same for all affected languages.
In summary: On some pages in certain languages, the body section fails to load, resulting in the website not rendering or displaying correctly.
May 1, 2025 at 9:44 am #16986272
anandB-2
so you mean to say all my pages i just need to edit and save it in english and it will get fixed in all languages ?
May 1, 2025 at 10:33 am #16986369
Dražen
yes, that should be the case.
Drazen
