If you're experiencing issues with weird URLs for your translated posts, such as URLs containing '__trashed' segments, we can help you address this.
First, ensure that your WPML Multilingual CMS is updated to version 4.8.4 and that you have also updated the LiteSpeed Cache plugin. Next, clear the trash for posts to remove any residual data that might be causing URL disruptions. It's also crucial to translate the parent category 'Language Learning' into other languages and perform a Hierarchy Synchronization in WPML under Taxonomy Translation for Categories.
To correct the URLs for existing translated posts, edit the original post, switch to the other language using the language switcher at the top, and then update the link accordingly. Before making these changes, please back up your database to prevent data loss.
Additionally, you can manage category translations directly in WPML under Taxonomy Translation.
If this solution does not apply to your situation, or if it seems outdated, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If issues persist, please open a new support ticket.
Last updated by Andrey 6 months, 3 weeks ago.
Assisted by: Andrey.
October 27, 2025 at 2:44 pm #17522635
joelA-13
Hello!
Further to the issues I have been having, I have just created a new blog post:
I have also translated this post and it is creating very weird URLs for the translated posts...
Here are just a couple:
Many thanks for your assistance and I look forward to getting these issues resolved and understanding why they are happening,
Joel
October 27, 2025 at 3:47 pm #17522902
Andrey
WPML Supporter since 06/2013
I have reviewed the issue you've encountered. At this point, I cannot determine why you received those specific URLs, as I haven't experienced a similar situation before. The setting in WPML → Settings → Translated Documents Options; the slug should be set to "Auto-generate from title (default)."
Are you able to replicate the issue by creating a new test post and translating it into another language?
Before proceeding, please complete the following steps:
1. Update WPML Multilingual CMS to version 4.8.4.
2. Update the LiteSpeed Cache plugin.
3. Clear the trash for posts.
4. Translate the parent category "Language Learning" into other languages.
5. Perform a Hierarchy Synchronization in WPML → Taxonomy Translation → Categories.
To resolve the current link issue, edit the original post, using the language switcher at the top to switch to the other language, then update the link accordingly. I have attached a screenshot for your reference.
Before making any changes, please ensure that you back up your database first.
October 27, 2025 at 4:40 pm #17523131
joelA-13
Hi Andrey,
I have managed to do all the things above apart from translating the parent category - I am not sure how to do that?
Apologies,
Joel
October 27, 2025 at 4:44 pm #17523135
joelA-13
Hi again,
I have just tried translating another post that is ready for translation and I am pleased to confirm that it has translated as expected, including the URL.
October 27, 2025 at 4:47 pm #17523138
Andrey
Hello Joel,
You can also go to WPML → Taxonomy Translation → Categories and translate it from there.
I have attached the screenshot for your review.
October 27, 2025 at 4:48 pm #17523155
Andrey
Thank you for your feedback.
I'm happy to hear that it went well.
