The client is experiencing issues where they are initially taken to the Translation Queue instead of directly to the translation editor when starting a new translation for products. Additionally, they encounter errors such as 'WPML couldn't translate this page' and 'The website is under heavy load' when attempting to translate certain templates.
We have identified that the issue occurs specifically with a certain template and not with other pages or posts. The problem persists even when exporting and importing this template into a different custom post type and attempting to translate it. Since the root cause is unclear, we have escalated the matter to our second-tier support for further investigation. We will provide updates as soon as we have more information.
If this solution does not resolve your issue, or if it seems outdated or irrelevant to your case, we highly recommend checking related known issues, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. Should you need further assistance, please open a new support ticket.
Last updated by pavlinaD 1 year ago.
Assisted by: Dražen.
March 26, 2025 at 12:53 pm #16862952
pavlinaD
Hi Drazen,
We tried the steps you suggested when translating another product but we encountered errors similar to the errata you mentioned.
After changing the DB collation, it seems to have been fixed.
However, we noticed that when starting a new translation for products, we're taken first to the Translation Queue. Without any action, if we edit the same product translation, we're then taken to the translation editor.
We tried the solution mentioned here https://wpml.org/forums/topic/translation-queue/ but that didn't give any results.
Is there a way to skip going to the queue first and go straight to the editor?
March 26, 2025 at 1:27 pm #16863092
Dražen
I checked and could see it happens only for this specific template, it works fine for other pages /posts.
The same issue happens if I export this template and import it into Post CPT, and then try to translate.
I could not find what is causing the issue, so I have escalated this to the 2nd tier, and they will check and advise further.
I will update when I have some news.
Drazen
March 27, 2025 at 12:39 pm #16868467
pavlinaD
Hello Drazen,
Thank you for escalating and troubleshooting this bug.
Do you have any updates from the 2nd tier team?
We have planned to work on the products' posts (updating the design in Elementor and proceeding with translation) as part of the preparation to launch the site, and we'd like to plan accordingly so that there's no risk of our work or yours being affected.
March 27, 2025 at 1:47 pm #16868784
Dražen
thanks.
It will take a few days before we check and debug it. I have taken a copy of your website and shared it with the 2nd tier, so you can work on your staging site, just make sure you have backup just in case.
Drazen
April 1, 2025 at 12:21 pm #16882788
pavlinaD
Hello Drazen,
Do you have any information from your team?
Thank you and looking forward to hearing from you.
April 1, 2025 at 12:35 pm #16882872
Dražen
We are still checking, we have a bit higher queue in 2nd tier support, sorry for the delays.
Let me ping our 2nd tiers again and try to speed things up.
Drazen
April 2, 2025 at 1:35 pm #16887372
Dražen
seems the issue is because you have enabled showing warnings and that causes issue.
You have an .user.ini file in the WP root, where is set
display_errors = 1 if you set it to 0 it works fine.
Drazen
April 3, 2025 at 11:59 am #16891937
pavlinaD
Thank you for getting back.
I checked the file and perhaps you changed the display_errors value to 0.
I'm not sure how it works for you but when we tested from multiple devices and browsers we got the following behavior:
1. When clicking to add a translation for a product we get the 'WPML couldn't translate this page" error hidden link. Nothing happens if we click 'Try again'
2. If after that we click on the plus icon for the same post and language translation, the editor opens but never loads hidden link
3. Then when at the same time a colleague tried to do the same action she got 'The website is under heavy load' error from WPML hidden link
The issue is getting worse and it doesn't seem like normal behavior.
Can you please look into it more?
April 3, 2025 at 12:15 pm #16892099
Dražen
the issue should be fixed, and it worked fine before. The issue you are experiencing and see now is related to another thing, and that is that we currently have a problem with ATE server on our side.
We are working on fixing it, and it should be fixed in a few hours.
Can you please try again later, and it should work fine. If not, let me know and I can re-check.
Drazen
April 4, 2025 at 10:00 am #16896599
pavlinaD
Hello, Drazen,
We checked again today, and as you said, after the server issue on your end has been fixed, the translation works as expected.
Thank you for the support and have a great day.
