You are trying to see a translated string in the WooCommerce Wallet system, but it is not displaying as translated. You expect to see 'Kredit u novčaniku kroz kupovinu #' but instead, you see 'Wallet credit through purchase #'.
First, ensure you back up your site and database. Then, navigate to Plugins > Add new > Commercial and check for WPML updates. Install and activate the latest versions of our plugins. If updates are available for the WpResidence Theme or other plugins, please update them as well. After updating, reapply the translation for the string and check if the issue is resolved.
If this solution does not resolve your issue or seems outdated, we recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the problem persists, please open a new support ticket.
Last updated by 11 months, 4 weeks ago.
