The client has translated a string, but the translation is not visible on the front-end; it only displays in Dutch.
We recommend that the client provides a screenshot of where the string appears on the website and details on how it was added. This information will help us understand the issue better and ensure that the correct string has been translated.
If you're experiencing a similar issue, we suggest you double-check that you have translated the correct string and provide us with a screenshot for further assistance. If the solution provided here is not relevant to your case, possibly because it's outdated or not applicable, we encourage you to open a new support ticket. We also highly recommend checking related known issues, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins.
If you need further assistance, please don't hesitate to contact us on our support forum.
Last updated by Andrey 1 year, 2 months ago.
Assisted by: Andrey.
March 22, 2024 at 8:14 am #15439151
karinaM-4
I have translated a string. But the translation is not visible on the front-end. It is just showing up Dutch.
I have already searched for it with activating automatic registration strings. But no luck that there is another string as well with that text.
The text is in dutch: Om je pakketje te bezorgen hebben we ook je huisnummer nodig. Voeg deze toe in het adresveld.
March 22, 2024 at 11:00 am #15439965
Andrey
WPML Supporter since 06/2013
To better assist you, could you please provide a screenshot of where the particular string appears on your website and how it was added? This will help me gather more information to determine what can be done to address the issue. Also, kindly ensure that you have translated the correct string.
