I am trying to restore the URL of a category for posts on my website to its original form. The URL has been translated into Korean, and I want to revert it back. We are not using WooCommerce.
The URL of the category for posts on our website has been translated into Korean.
How can I restore the translated category URL back to its original form?
There is an option to adjust this. Navigate to WPML > Settings > Translated documents options > Page URL > Copy from original language if translation language uses encoded URLs . I've attached a screenshot for our reference.
1. Now these URLs have been translated into Korean, how can I restore them to the default English URL?
For example, the URL before translation is hidden link
After translation, it becomes: hidden link
Can the translated URL still be the default English?
2. In addition, I am not sure whether my original method of translating Categories is correct. Can you tell me the correct steps to translate categories?
Hello!
I know you are very busy, could you spare some time to help me solve the following problem?
Re-send
Hi Kor,
Thank you for your guidance.
Thank you for the operation video you made for me.
I found that there are still two problems:
1. After changing the category page link back to the default language English, the page layout is different from before the change.
Before the change:
After the change:
Can you help me solve it?
2. Whether before or after the change, some SEO parameters of the category page, including keywords and Meta Description, are not translated. Does this need to be translated manually?
Sorry for breaking your category page. I'm not sure why changing the slug would break it. Could you restore the staging site from a backup so that I could check again?
As for your second question, yes, you need to translate it. Try searching for the strings using the String Translation.
1. I don't have a new cache site now. Please use the website access information I sent you last time to further check the problem that the page layout changes after the category page is translated and the slug is changed. The detailed description is that the entire layout has changed, and the sidebar is gone, but the product list is there, but the style has changed.
Take Adipate esters as an example,
Before translation: hidden link
After translating to Korean and changing the slug to English: hidden link
Before translate screenshot, please find attachment.
After translate to Korean and after change slug, please find attachment.
2. Another related problem is that after the category page is translated, whether it is Korean or Japanese, the product list column of the category page is gone, and other layouts have not changed.
After translation: hidden link
After translating Japanese hidden link
After copy, it shows: hidden link
Before translation Japanese screenshot, please find attachment.
After translation Japanese screenshot, please find attachment.
2.1
When I translated the category page into Japanese, Japanese characters appeared in the link slug again. How can I keep the default language when translating into other languages in the future?
2.2
For the category pages that have been translated into Japanese, how do I change the link to the default English one? Should I still follow the video you posted about changing the category pages from Korean back to English?
For your reference, I use Elementor pro to edit category pages
I regret any inconvenience caused, but to proceed with troubleshooting, I kindly ask for a snapshot of the site. Alternatively, with your permission, I can create one myself. For this purpose, I typically recommend using the free plugin "Duplicator." If you're already familiar with Duplicator (https://wordpress.org/plugins/duplicator/), please skip the following steps and simply send me the archive file you downloaded.
I apologize, as I am a beginner and have only installed Duplicator. I am not sure how to proceed with the next steps, so I would appreciate your help. Could you please create a snapshot of our website? Thank you for your hard work.
Following up on my previous email, I noticed that my WPML is not translating the Widget Posts from Elementor Pro, whether they are in the pages or in the archives. I hope this email can help you assist me in resolving the issue.
Best Regards,
Hongjian Wang
