The client noticed that all Spanish translations of their blog posts were redirecting to the homepage instead of the individual blog posts.
We recommended checking if the translated posts were visible on the frontend when logged in as an admin. If visible, the issue might be that the posts are in Draft mode. The client should edit these posts and publish them to see if this resolves the issue.
If this solution does not apply or is outdated, we recommend opening a new support ticket. We also advise checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. For further assistance, please visit our support forum at WPML support forum.
Last updated by Long Nguyen 1 year, 8 months ago.
Assisted by: Long Nguyen.
July 30, 2024 at 11:53 pm #16022599
jamesL-26
I was entering some new blog posts in English today and when I checked the Spanish translations I noticed all of our blog posts point to our home page, not the individual blog posts. How can I fix this?
July 31, 2024 at 3:01 am #16022798
Long Nguyen
WPML Supporter since 02/2022
Languages: English (English ) Vietnamese (Vietnamese )
Hi James,
Thank you for contacting WPML support, I’m happy to help you with this issue.
If you login to your site with an admin account, do you see the translation post in the frontend? If yes, it is possible that the translation post is in Draft mode.
Please edit the translation post and publish it then check the issue again.
If it does not help, I would like to request temporary access (wp-admin and FTP) to your site so I can take a better look at the issue. It would be better to have a testing site where the issue is replicated. Your next reply is set to private to share the info.
August 3, 2024 at 6:16 pm #16035830
jamesL-26
Hi Long,
Sorry to keep you waiting. I'd like to keep this ticket open. I've been working on things and will have a few questions that I'd like to submit on Monday.
Thank you,
Jim Lawrence
August 5, 2024 at 1:20 am #16037270
Long Nguyen
I'm waiting for your feedback.
August 5, 2024 at 8:57 pm #16042091
jamesL-26
Hi Long,
I was able to get the translations to update with valid links to their respective content. It was a frustrating process. Like you, I tried disabling plugins, changing the theme to the default, etc. What it took was forcing the translations to re-translate with all caching and security tools turned off. Again, quite frustrating.
The last problem (for now) is to learn why the Spanish translations are not retaining formatting information compared to the original English posts. Let's use this one post as an example: hidden link
Use the language switcher to change to the Spanish version: hidden link
The line breaks in the blockquote lists do not carry over to Spanish.
Here's another post where formatting does not carry over: hidden link
And the Spanish version: hidden link
I'm happy to give you admin access to WP and FTP, but this does not look like the secure form I was expecting.
Let me know if you'd like access.
Jim Lawrence
New threads created by Long Nguyen and linked to this one are listed below:
https://wpml.org/forums/topic/the-line-breaks-in-the-blockquote-lists-do-not-carry-over-to-spanish/
August 6, 2024 at 2:03 am #16042335
Long Nguyen
I understand the issue with the translation posts pointing to the homepage is resolved. We limit one issue per ticket only so I will split your new issue with the line breaks into a new ticket for better handling.
