This topic contains 6 replies, has 3 voices.
Last updated by lucd-15 1 year, 10 months ago.
Assisted by: Long Nguyen.
February 21, 2024 at 10:59 am #15327093
lucd-15
We've installed the WPML plugin on the website (base language is EN) and the translated pages are loading an older version of the theme with template parts no longer in use.
For example this page : hidden link
When translated : hidden link
Loads a different template (older) template.
When I try to edit the template for the translated page (like I would for a page with the wrong template), the theme editor loads the right one.
I have tried changing the URLs settings to pass the language as a parameter but it didn't help.
February 21, 2024 at 7:53 pm #15330340
Lucas Vidal de Andrade
WPML Supporter since 11/2023
Please try to make a small change in the original content (like adding a small space at the end of a text) and update the translation to save it. If it's something temporary, that should solve it.
February 21, 2024 at 10:14 pm #15330572
lucd-15
Hello Lucas,
Thank you for your reply. I tried to apply the quick fix (updated the linked page in its main language then updated the translation) but unfortunately this didn't solve the problem.
February 22, 2024 at 3:10 am #15330978
Long Nguyen
WPML Supporter since 02/2022
Languages: English (English ) Vietnamese (Vietnamese )
Please follow some troubleshooting steps below and let me know how it goes:
1. Increase WP memory limit: Please check this link for more details
2. Go to WPML > Support > Troubleshooting > Click on some buttons:
- Clear the cache in WPML
- Set language information
- Fix terms count
- Fix post type assignment for translations
Look forward to your reply.
February 23, 2024 at 8:00 am #15336249
Long Nguyen
The shared account isn't correct, can you please recheck this?
Regarding troubleshooting buttons, they help to correct translation issues on your site if they are available like: the count of term (taxonomy) isn't correct, a post is not set to a language, a ghost translation ... If you have a backup of your site you can run buttons or on the staging site and see if it helps.
Refer documentation https://wpml.org/documentation/support/wpml-troubleshooting-options/
February 23, 2024 at 10:46 am #15337104
lucd-15
I recreated (and tested) the user with the password I sent yesterday, you can login now.
Please excuse me for the mistake.
February 23, 2024 at 10:51 am #15337183
lucd-15
Thank you for the clarification.
I performed all 4 steps you mentioned with WPML troubleshooting tools, unfortunately the translated pages still load the old template.
Bruno
February 25, 2024 at 4:33 pm #15341612
lucd-15
Hi Long,
I have resolved this issue using a simple workaround: I duplicated the WP child theme with the native WP tool and this resolved the problem - I think the old template parts in the database weren't being referenced by the new duplicated theme anymore.
Thanks for your assistance!
Kind regards,
Bruno
