The client reported that a product, fully translated into German, was not displaying on the German site and instead was giving a 404 error. Despite updating WPML plugins, the issue persisted. The client also noted that other German products were displaying correctly, which suggested that it might not be a template or plugin issue.
We first ensured that the client was using the latest versions of WordPress and WPML. We then requested temporary admin access to the site to investigate further. Upon access, we noticed several outdated plugins that needed updating, which could affect translations, such as WooCommerce and Elementor. After updating these plugins, we checked the specific product and found it was still in 'draft' status in the German version. We were able to change the status to 'published' successfully, resolving the issue.
If you're experiencing similar issues, we recommend ensuring that all your themes and plugins are up to date. Also, check the status of the translated products to ensure they are not set to 'draft'. If these steps do not resolve the issue, it might be due to a different cause or the information might be outdated. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the problem persists, please open a new support ticket.
Last updated by Marsel Nikolli 1 year, 2 months ago.
Assisted by: Marsel Nikolli.
May 13, 2024 at 10:03 am #15619788
kasperG
This product is 100% translated: hidden link
Yet it is not showing on the german site hockeyproshop.de. When switching language a 404 is given.
May 13, 2024 at 10:57 am #15620258
Marsel Nikolli
Thank you for contacting WPML Support, I will gladly help you.
From the debug info you shared I've noticed that you are using WP v6.4.2 and WPML v4.6.9, I suggest you update to the latest version and check if the issue persists.
* Note: Please make sure you have a full backup of your website before making any updates/changes to your website.
* I can't access the link of the product you shared, can you please share the front-end link of the product?
Kind regards,
Marsel
May 13, 2024 at 11:04 am #15620343
kasperG
Hi Marsel
Thank you for your kind replt.
My apologies for now pasting in the link to the frontend product. This is the one in question: hidden link
As you can tell from the attached file it's 100% translated.
I tried updating the WPML plugins. I did not solve the issue.
The Status also looks like everything is OK.
Let me know what you think.
Best, Kasper
May 13, 2024 at 11:06 am #15620362
kasperG
Here's the status page.
May 13, 2024 at 1:04 pm #15621086
Marsel Nikolli
Thank you for the update, I would need temporary access to your site's WP-admin to investigate this issue and understand it better. Please create an administrator user using any email address you prefer
Please fully back up your site (files and database) and confirm it in your next reply.
Your next reply is set to private for you to provide the username and password details.
Marsel
May 13, 2024 at 1:08 pm #15621091
kasperG
Hi again
You can use:
User: [Removed]
Pass: [Removed]
May 13, 2024 at 1:31 pm #15621132
Marsel Nikolli
Thank you for the access, I've noticed that there are quite a few plugins that require updating on your website.
I would need you to proceed with the updating of the plugins (as some of them might affect the translations ex. Woocommerce/Elementor).
Let me know if the issue persists after the updating.
May 13, 2024 at 1:33 pm #15621141
kasperG
Hi
The odd thing is many german products are translated and showing just fine. If it was a template or plugins issue I'd suspect none of the german products would be showing. Right?
May 13, 2024 at 2:09 pm #15621328
Marsel Nikolli
Can you please share 2/3 links to products from the same category?
* I checked 1/2 of the ones showing at the bottom of the product page but on my end, they were having the same issue (they redirected to the German homepage).
The product in German, when I am logged in, does open but the URL is showing like this:
May 14, 2024 at 11:20 am #15624885
kasperG
Hi again
I find it a bit odd that there are two categories with the same name.
Also see this category: hidden link
All these products are working OK.
I did also noticethe product is in “draft” - hidden link
I cannot be changed to published.
May 14, 2024 at 1:34 pm #15625599
Marsel Nikolli
Thanks for the update.
I checked your website and I was able to publish: hidden link just by clicking the "Publish" button. Please check if it's working correctly on your end.
As for the categories having the same name, they can have the same name in different languages as the ID, and the slug works as a unique identifier and they can't be the same in different languages.
Let me know if you have any other questions or need further help.
Marsel
May 15, 2024 at 7:12 am #15627918
kasperG
You're right. It works perfectly. Thank you.
