Last updated by Kor 1 year, 3 months ago.
January 31, 2025 at 5:54 pm #16656902
marinaB-21
Also i am facing another issue with highlited quotations:
The closing character must be reversed. See image
If helps to resolve the problem, you can just use the english signs everywhere, but it would be better if you could correct it
how can I manage this problem for other articles such as this one? hidden link
How can this be resolved?
February 3, 2025 at 6:44 am #16661082
Thanks for your reply.
Could you isolate this issue on a new test page and share the link with me so that I could check?
February 3, 2025 at 6:05 pm #16664017
marinaB-21
Yes, I included it in the same post as the other issue.
In the German version (hidden link), I placed "Ein Wort zwischen diesen Klammern".
However, in the French version, the auto-translation incorrectly converts the brackets, using « « instead of « ». See screenshot
Since I frequently update the posts, manually correcting this each time is not a viable option, as the auto-translation would overwrite it.
February 4, 2025 at 5:10 pm #16668026
I've tested it here hidden link and it seems to work fine when I translated it. Could you login to this sandbox site and try to replicate the issue you had there?
here is the login URL : hidden link
February 5, 2025 at 4:15 pm #16672256
marinaB-21
Hi - for some reason it started to work. Have you done something on our site to fix this?
February 5, 2025 at 4:17 pm #16672257
No, I did not do anything. Are you referring to my sandbox site or your Website?
The topic ‘[Closed] Translation issue with highlighted quotations’ is closed to new replies.
